RV.Net Open Roads Forum: Class C Motorhomes: Wind noise as I drive
 > Wind noise as I drive
pugg3970
MERRITT ISLAND, FLORIDA
Posted: 05/07/08 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
I currently own a 32' 2008 Winnebago Access. Currently as I drive on the highway I am hearing wind noise coming from the entrance door to the RV. As a new Rv owner I was wondering if this is a normal thing that happens to some or all class c rv's.
mod. edit: Removed all caps in topic.
* This post was edited 05/07/08 09:14pm by an administrator/moderator *
352
Oxfofd, Fl
Posted: 05/07/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
could be normal.all depends if the little lady is happy
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters.
just a good ole southern redneck country boy.our favorite place to go to swim with the manatees
Cool Mike
Mendocino. Calif.
Posted: 05/07/08 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
If you can hear an air leak, you have one, and so do we. Its not easy to keep the side door air tight when its not adjustable, and doesn't have double gaskets like the doors on the cab of the truck. You might try a thicker foam seal, but we learned to live with it, ours isn't all that bad.
2001 27' Four Winds Class-C E-450 V-10.
Buick Park Ave Ultra, Ford Ranger PU, JD 500 backhoe.
1941 Farm All "A"
ramzfam
Appomattox, Va
Posted: 05/08/08 05:32am Link  |  Quote  |  Print  |  Notify Moderator
I've got one too. Can't be sure where it is exactly. DW has looked for it but can't find it and since she won't drive the motorhome I haven't been able to pinpoint the leak. We've gotten used to it though maybe someday it'll be fixed.
Have RV....Will Travel
2007 Forest River Sunseeker 2860 LTD
2000 Jeep Wrangler Sahara
Berticus
Boise, ID
Posted: 05/08/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
I have(had?) one too. This is what I have found 2 wind/noise issues when doing my Floor Replacement Project.
I removed the wood trim for the door and found at least a 1/2" gap in between the door frame and wall. The door latch and dead bolt our just openings into this open area with no gasket around it. I sealed up the gap with great stuff door/window foam and made a gasket(rubber gasket) to go around the latch assembly.
The other issue was the step going out. In my rig you have 1 step going down inside of the rv then 2 step outside. The inside one had gaps here and there on its seals. I took this out and made some shims on the bigger gapped areas and but a 1/2" thick rubber gasket where it rested on the floor and wall.
My 1st trip is planned for the 16th and hope to test out all my repairs but I am pretty sure I could not have made anything worse.
Good Luck and Safe Camping, Robert.
The Setup:
96' Serro Scotty 25' 4x4, Diesel, Class-C(pic coming), 86 20' Chris Craft LTD,69 Wife,02 1st Son,04 2nd Son,2 dogs (Yellow Lab & Border Collie).
bsshelby
Paducah, KY, USA
Posted: 05/08/08 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Take some wide masking tape and tape all around the entrance door on the exterior (closing the gap between the door and the body of the RV). If this stops the air sound, then you know it's the door. Then start removing the tape in about 8" pieces. Take a piece of tape off and drive, do this repeatedly until you hear the noise return. Then put that piece of tape back on the door. If it stops the noise again, then you have locate the most likely place of the problem. Once you have located the problem area you can try adding some additional gasket to that area. The problem I have run into is sometimes it just sounds like the noise is the door. Be sure and have someone listen close to the side windows in the bunk area above the cab. I found one there on a Winnebago class c I had. You mentioned being a new RV owner, the next noise is likely going to be a rattle at the entrance door latch. That is usually solved by rapping electrical tape tightly twice around the small door post in the latch part of the door. Good luck!
pugg3970
Posted: 05/10/08 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the great tips. Its good to know when help is neeeded,folks like all of you are here to help a few Rver and newbie.
ct camper
ct
Posted: 05/10/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the door is completely closed also. Sometimes you need to really pull on the door to get them to close espec. if you are entering the coach through the house door.
* This post was edited 05/10/08 06:46am by ct camper *
trnfla
Tampa
Posted: 05/10/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I just listen to it and realize how lucky we are to be able to enjoy nature without having to stay in a strange bed... Thats just me though......
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
PapPappy
Wilmington, NC
Posted: 05/10/08 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Being as you've got a 2008 Winnebago, I'd make a stop by the dealer, and see what their Tech says. It may be a bad seal, a warped door frame or door, and should be covered under the warranty. It all depends on just how much it bothers you. Also, I'm guessing that you have a 31' RV, not a 32' (or was that a typo?) as that is the standard number.....31-C, even though it's actually a bit longer.
The suggestion of using tape is good, as you may find out that it's not the door, but the window in the door? Also, as mentioned, the door has to be really shut. I've found that on occasion, our door isn't really closed, when we pull it shut from inside....it's not as if the lights stay on, as they do in the family car!
I don't think that you are really "listening to nature" when you are driving down the road at 55-65 mph, so I'd want the door leak fixed. Besides, an air leak that lets noise in, will also let A/C out....maybe only a little bit, but it's still a leak!!
JMHO
Bill, Claudia, and the Paps
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
