RV.Net Open Roads Forum: Fifth-Wheels: No Fuss Black Tank Flush System ???
 > No Fuss Black Tank Flush System ???
jjfay03
Washington State
Posted: 05/07/08 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
We'll today I went out and was getting the rig ready for the camping season and was adding water to the system and no problems. I thought "Wow" no damage from the winter. Then I hooked up the hose to my "No Fuss Flush, Black Tank Flush System" and turned the water on and waited for the water to start coming out of the tank, but I was only getting a little bit of water. I look by the water pump where all the water hoses are and I saw water dripping down from the hose that connects to my garden hose. This is where I am confussed. I followed the hose from my water station and it goes up into the wall. This is another place that I am confussed at, why would it go up and not just down into the black water tank? Anybody have an experience with this system? Could it be a defect and not damage from freezing? Any info appreciated. John
John and Jeannine + 3 Boys 9, 6, and 4.
2007 Dodge 2500, 5.9 CTD LB, Husky Brake Controller,
Husky 20K Hitch, Linex, and Firestone Airbags, Pac Brake.
2007 Keystone Challenger 34' SBH 5er
I can't forget the puppy, Little Boy!
N9MB
Indiana
Posted: 05/08/08 03:27am Link  |  Quote  |  Print  |  Notify Moderator
The flusher on my old Everest ran up the wall behind the shower and back down from there. There was also an anti-siphon valve behind the shower which came loose once. Best I can figure is the routing is to avoid the possibility of back flow from the black tank.
Good luck
F350 PSD CC DRW Tow Boss
Heartland Bighorn 3600RE
Airsafe Revolution
ShapeShifter
Buffalo, NY
Posted: 05/08/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Yes, the supply pipe is supposed to run upwards to an anti-siphon valve, which is a standard part of the No-Fuss Flush system. This valve (vacuum breaker) must be mounted higher than any part of the black tank. On my rig, the pipes run up under a bathroom sink cabinet, with the valve mounted high up just below the sink.
Hopefully, it's a simple fix, and it's just something loose.
I hadn't considered it before, thanks for the heads-up! That's one more thing to add to the winterizing list, I must've gotten lucky over the winter!
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
JEBar
Willow Springs, NC
Posted: 05/08/08 06:01am Link  |  Quote  |  Print  |  Notify Moderator
as others have correctly noted, if you follow the line, it will take you to the anti backflow valve ... had one go out on our 5er and found it through taking the shower knob access off .... as also noted, if you can get to it, replacement is relatively simple
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 05/08/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I always blow out the flush system with compressed air just to be sure when I am winterizing.
jjfay03
Washington State
Posted: 05/08/08 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
I know that now! I wish the dealership would have told me or I wish that I would have thought about that when I was winterizing last Fall/Winter. You can bet next year I will remember. John
