RV.Net Open Roads Forum: Class A Motorhomes: Working on the windshield
 > Working on the windshield
grinder
Courtenay, British Columbia
Posted: 05/08/08 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Bon-Ami, yes, very good window cleaner, we can still get it up here. Was a powder, now a spray liquid.
Ted
Courtenay, BC
OnaQuest
Raleigh, NC
Posted: 05/08/08 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Any ideas about what Bon-Ami and buffing would do to/for a sand pitted windshield?
lou
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
Jim1eddoc
Apple Valley CA
Posted: 05/08/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Another suggestion, I use a product called "Mr. Clean, magic eraser"
You or the wife can find it in the market. Because of the water run off the roof, my "plastic" glass above the driver/passenger windows streak and won't clean with normal soap and water.
I use it for all kinds of things like cleaning water spots and soap from the shower glass.
TEO
Inverness, FL, USA
Posted: 05/08/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
I'm still working on the windows, of course I started yesterday! I finally realized that the "substance" on the glass is so thick that I can feel the roughness. It finally dawned on me that I might be able to scrape most of it off with a razor blade. I tried it and it works. What's left is a much thinner layer of spots that is so much easier to remove. I'm still using rubbing compound and the result is a very clean, very smooth glass surface.
I did try Magic Eraser with no success.
Paul
Paul & Helen
2002 Winnebago Journey DL
1999 Jeep Cherokee toad
Yellow Lab, Jodie and Chocolate Lab, Coco
FMCA 98905
Rich D.
New England
Posted: 05/08/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
If all else fails polish it with this kit. You can also remove scuffs or wiper marks; anything that is not deep enough to catch with a fingernail. I've used this on antique auto glass with great results too.
Link to Eastwood Products
Rich D. Wanderlodge LXi 43'
carp65
Sioux Falls, SD
Posted: 05/08/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use Nu-Finish liquid wax on the windshield. Makes the water bead very
nicely, cheaper than Rain-x and elimiates, bugs, tar, pine sap, etc. Great
stuff--works well on the body, too.
hambug92
Posted: 05/08/08 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Invisible Glass. Bought it at Kragens. Also saw it at Walmart. The windows look like new.
tatest
Oklahoma
Posted: 05/08/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
If the MH has been in an area with alkaline rain, or alkaline dust with occasional rain, then those spot aren't deposits, they are etched into the glass. You can't clean them off, you have to polish or fill.
BonAmi is a polishing product that helps fill etchings, and there have been RainX products that fill without polishing.
P.S. Another good scratch and spot filler was GlassWax, haven't seen that for years.
But I see that you've figured out your problem isn't etching, your glass just needs a good polishing.
* This post was edited 05/08/08 03:26pm by tatest *
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
ScottG
Bothell Wa.
Posted: 05/08/08 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Skylark wrote:
Scott, where did you find BonAmi? thanks sky
You know, I've had it for so many years I dont know where I got it for sure - probably the grocery store.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
ScottG
Bothell Wa.
Posted: 05/08/08 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
lou
Probably nothing, it's not abrasive at all.
