RV.Net Open Roads Forum: Tow Vehicles: '05 Nissan Vs '06 Nissan Titan
Search only in Tow Vehicles
 > '05 Nissan Vs '06 Nissan Titan
twmw1126
Versailles, KY
Posted: 05/13/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 SE Kingcab. No problems. 22,000 miles of which 12,000 has been towing. I only drive to tow now because of gas prices. That would be the only draw back I have with the Titan. It is a very solid truck. Would I buy the Titan again? Absolutely.
Mickey & Teri
2006 Nissan Titan SE
2008 Flagstaff 829BHSS
Keith99RS
Suffield, CT
Posted: 05/13/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
cdivrmike wrote:
If I go with 4x4 does that take away from my towing weight because of the added axle, differential & drive shaft?
IIRC my 05 SE CC 4X4 is rated at 9,200lbs. The XE's get the 9,500lb rating. XE is the stripped model. Crank windoes, bench seat and so on.
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
mtofell1
Oregon
Posted: 05/13/08 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I had an 05 that was a late 04 build date. Easily the best 1/2 ton I've ever owned... Titans are really nice. I had the breaks replaced under warranty at about 10K miles... otherwise, no problems whatsoever.
I upgraded to a Duramx and love it for towing. As a daily driver I really miss the sportscar feel of my Titan. Forget just the best 1/2 ton truck.... that was the best all around vehicle I ever owned.
