browns329
New Jersey
I am about ready to purchase a pressure regulator and had some e-mail correspondence with Rick from RVWaterfilterstore.com. I think I may buy the Watts 263A with gauge for $60. Is this a good choice?
I also told him that I had the following in-line filter that I bought at Camping World for about $20:
FILTER
He explained some of the advantages of a canister filter. Does anyone have comments on the effectiveness and ease of use of a canister filter vs. in-line filter?
EDIT: Also, is there any difference in performance or price between the filters at RVwaterfilterstore.com and any others out there (e.g. Culligan, etc.)?
edited 05/09/08 06:05pm by browns329 *
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
skipnchar
Topeka Kansas USA
Biggest advantage to the cannister type filter is it can be positioned to filter water coming from both the pressure water system AND the Fresh Water Tank. It makes the water taste as sweet and pure regardless of which water source is used or which faucet it's drawn from. It's an option I would probably NOT have ordered but since it was standard equipment on my Rockwood, now I'm COMPLETELY sold and won't be without it again. My system is from PUR but it probably doesn't make any difference about the brand as filters are pretty much low tech items.
browns329
New Jersey
skipnchar wrote: Biggest advantage to the cannister type filter is it can be positioned to filter water coming from both the pressure water system AND the Fresh Water Tank.
How would this be done?
plumber1
evensville,tn.
browns329: The watts pressure regulator is probably the finest on the market. The in-line filter I use attaches to the hydrant at camp site, this keeps my fresh water hose clean as well as the rest of the water supply in TT.
Steve
skipnchar
Topeka Kansas USA
My filter is positioned in the water line just after the pressure water line enters the line from the pump so either water source is passed through the filter before being distributed to the entire trailer.
tvman44
Southwest Louisiana
I use a Whole house water filter that I got at Home Depot, a little pricey but last a whole lot longer than the little cheap blue ones for RVs. One weekend in a campground with a lot of iron in the water and the little blue one is saturated and the pressure drops unreal and you still get yellow water. The whole house filter is so much larger and has a better flow rate and last so much longer, it was worth the extra money to me. The watts regulator is a fine regulator from what I have read and heard, I use a regulator I got from Camping World Camping World that works pretty good but if it ever goes out I will get a Watts.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
tvman44
Southwest Louisiana
I forgot to mention that the adjustable regulator from Camping World has a much higher flow rate (abt 15 gpm) than the little fixed regulators and is sold by Valterra.
browns329
New Jersey
I went to Home Depot today, and did not really see anything that would work well.
arasgrandpa
WA (Summer) AZ (Winter)
I have used both kinds on my RVs. The inline you throw away every 6 mos to 1 yr depending on usage, but mine also broke at the hose connection a couple of times. For my 5er and now the TT, I got a Home Depot filter and adapters to fit a water hose, one hose from faucet to filter, one fom filter to RV. That way I can use the quality of replacement filter I want, depending on circumsances and use it to fill tank as well as house water.
Got mine on sale at HD for about what one of the in lines cost at CW.
Arasgrandpa (47)
Arasrana (46)
2001 F150 SCrew (Gotts Mod)
2008 Trail Cruiser TC23SB
http://lotsastuff.tommymartin.info
browns329
New Jersey
For those that have a household model from Home Depot, Lowes, etc...What type do you have?
I'm wondering if it is the same or similar to the canister filter sold at rvwaterfilterstore.com and how the price compares.
