CCIntrigue
North Carolina
I want to get my DH an orbital buffer for Father's Day. We've been waxing the MH by hand, and it takes forever. I've been reading about a lot of different brands on the internet, but I can't figure out which would be best. We need something that isn't too heavy - I want to be able to use it, too. But something powerful enough to remove the wax and bring out a nice shine. DH wanted a cordless buffer, but everything I've read says they aren't powerful enough to remove wax. Any ideas/suggestions? I'd like to keep the cost to $200 or less. Thanks for your help!
Country Coach Intrigue
Miata and golf cart trailered on Featherlite
1 handsome husband
Kassie, our Miniature Schnauzer copilot
chastho
arkansas
I use a small palm sized buffer from wal mart, paid $15 for it. Used it for two years and it's still going. It's light weight and can use it with one hand. You can spend a lot more but unless you wax a lot more than I do you don't need to. I also have a 10" buffer that needs two hands but it got put in the shop when I got the small 5" one.
amore
Not what you should buy, but a suggestion. Wal-Mart Automotive sales a nice 6" buffer for $15. It's on the bottom shelf and they have all the supplies for it. Just like "chastho" said, I too have a 10" or 12" orbutal buffer, but it takes two hands and very steady ladder and you have to fight the cord. I use the big one once in a while for my car and truck, but being on a ladder for to do the coach, I only use the 6" buffer and it does a great job.
You might spoil him and get him both, that way he can cover both applications coach and car. Even if you did that, you'd still be under $75, so you can buy him some extra buffing cloths and a bundle of microfiber cloths and maybe a California Auto Duster.
The type of polish will depend on your husband's likes. It took me a long time before I found the polish/sealant that works best for me(Meguiars #21 synthetic sealer).
I use the 6" buffer to put on polish and sealant on, but take them off by hand with a microfiber cloth(it comes off pretty easy).
While your at WalMart in the automotive dept, find the Stoner Invisable Glass Cleaner and try it. You won't back to anything else.
I really thing your husband should by this for you, so he can watch you show him how it's done. ha ha Happy Mothers Day
amore
Rich & Vickie
2 Yorkies
07 Dynasty 43QIV Ralph Lauren LE
Explorer Limited in tow
CCIntrigue
North Carolina
Thanks for the suggestions! Will that $15 buffer also remove wax?
Amore, I do my fair share of waxing on the MH! Usually do at least half the outside plus all the inside cleaning/polishing. I oil the cabinets, clean all the glass, vacuum and clean the floors, and gel-gloss the countertops. Wait a minute -- does something seem out of balance here ?!?
wny_pat
Western NYS
CCIntrigue wrote: Will that $15 buffer also remove wax? Washing with Dawn dish soap will remove wax.
edited 05/10/08 08:20pm by wny_pat *
v8q
Oviedo, FL
go to properrvcare.com and look at the porter cable 7424.
They have all the right stuff, and tell you how to use it.
Dave Head
Oviedo FL
95 Foretravel U320C SE
M11, HD4060
dennis and terry
wisconsin
i'm with v8q; i recommend the porter cable 7424. there's more to polishing than wax on/ wax off. go to detailedimage.com or do a search on the porter. watch some of the how to vids. the unit is a lot pricier than the "jitterbug" polisher but time is valuable so i want long term results.
dennis and terry
2000 damon intruder 349 (The Boo-mobile)
cats Hunter and Jazz
dog Abigail (newly adopted from humane society)
1995 Saturn wagon toad
Kenneth
Washington, the state
The Porter-Cable #7424 random orbit buffer ($99) is great. It is a heavy duty item for years of service. You will also want the hook & loop backing pad (soft, not rigid) and a couple of foam polishing pads. The pads come in different hardnesses, medium for removing oxidation and soft for waxing.
But, I no longer use my buffer. I use RejeX polymer sealant. It gives the best looking job, stays the slickest, and lasts the longest of any wax or sealant I've used. The surface does need to have the oxidation removed (fine polishing compound) before the first application, then it is an easy hand wipe-on/let dry/wipe-off job.
DarkRubiTJ
Livingston, Tx.
Another vote for the Porter Cable. It's based on a 4 1/2 inch grinder, no big deal, however because it is, you can hold it in one hand. It's really easy to use that way, especially when you are on ladder polishing the MH.
FL Mike
Ormond Beach, FL
I use two 10" buffers from Walmart, about $25 each. One for wax on, one for wax off. Saves having to change the buffing heads all the time...
I have a 10" cordless, but as you said, it does not hold a charge long enoungh to get much done...
