RV.Net Open Roads Forum: Travel Trailers: anyway to get more pressure from shower?
 > anyway to get more pressure from shower?
Page of 5
fun2camp
PA
Posted: 05/12/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Used the new trailer this weekend for the first time. The shower pressure is awful (well, compared to home haha) Is there a way to increase the pressure?
Mary, Camp mom to 3 little boys (ages 2,4,& 6)
2008 Puma 31BHSS(click for pictures)
Midnightpumpkin
Concord Twp, Lake County, Ohio
Posted: 05/12/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
If your trailer has a built in water filter, try removing the cartridge from the filter and see what happens to the water pressure.
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
2007 Rockwood 8315SS Travel Trailer
Loaded Weights:
Trailer Axles 6640#, Hitch Wt 920#
Combined Gross Wt, no passengers, 13,855#
fun2camp
PA
Posted: 05/12/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I don't think it does, but I'll ask hubby.
AVid
SE Michigan
Posted: 05/12/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
There is a water flow restrictor in the shower head. Unscrew it from the hose and remove it.
If it was the water filter, the pressure at all the faucets would be low also.
Avid
fun2camp
PA
Posted: 05/12/08 07:25am Link  |  Quote  |  Print  |  Notify Moderator
ok thanks.. drives me crazy because I want a nice shower lol! but I am thankful I don't have to use the public ones!
canuk camper
Fort Saskatchewan, Alberta, Canada
Posted: 05/12/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
This might sound silly, but typically these shower heads are adjustable, which means you can stop the flow of water without actually turning the taps off. Just by turning the dial/ring on the shower head you can reduce the pressure or stop the flow of water. My wife also mentioned low pressure one day and I looked at it and discovered this feature and with a slight turn of the dial we had resonable water pressure again. Just a thought.
Ron
Jnbaun
Ridley, PA
Posted: 05/12/08 08:03am Link  |  Quote  |  Print  |  Notify Moderator
I had terrible shower pressure this weekend in the new TT too but it ended up being low pressure at the CG. I filled the fresh water tank and turned on the pump. The shower worked great then.
John
Wife - Renee and 2 boys ages 12 and 7
fun2camp
PA
Posted: 05/12/08 08:09am Link  |  Quote  |  Print  |  Notify Moderator
ok thanks!
Where did you guys go this weekend?
DocP
Brunswick Hills, Ohio
Posted: 05/12/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
We were also having a heck of a time with the low water pressure in the shower. A neighboring camper told us to check out his Oxygenics shower head. I did, and ended up buying one from CW. Here's a link:
Oxygenics shower heads
Note that these things are a bit pricey (I bought the white one when it was on sale for $24.99), and I swear to God the water pressure in the shower is better than I get at home. Apparently the unit mixes air in with the water, and the pressure is great. By far, absolutely the best modification I have made to the camper!!!
Note: there may be cheaper sources on the internet, but I did not check them out.
2008 Keystone Freedom Lite 281RL
2004 Chevy Avalanche, 5.3L, 3.73:1, 4X4,
Auxiliary transmission oil cooler,
Z71 off-road towing package
Reese Trunnion WD, Dual Cam, Prodigy
Yamaha EF2400IS generator
hwybnb
Posted: 05/12/08 08:26am Link  |  Quote  |  Print  |  Notify Moderator
If you are using one of those brass cylinder pressure regulators try taking it off. Those things restrict water flow a lot. You should see a big improvement if you use a residential pressure regulator. You can buy them at Home Depot or Lowes.
Page of 5
