busch2fan
Wauconda, IL
Another vote for the Oxygenics shower head...
Best thing I ever bought for the camper.
Me and my shaved head were fine w/ the original. But the DW DEMANDED an improvement...
The Oxygenics fit the bill. No more complaints from the DW means I'm a happy camper again!!
2006 Ford F-250 FX4 XLT Crew Cab 6.0 Powerstroke Diesel
2007 Montana Mountaineer Edition 32PRD
ProPride 3P 1400 hitch (ordered)
See my modifications here!
fun2camp
PA
thanks
Mary, Camp mom to 3 little boys (ages 2,4,& 6)
2008 Puma 31BHSS(click for pictures)
big dave
Soldotna, Alaska, USA
My MH has a flow restrictor in the valve assy., it's there to conserve fresh water and holding tank capacity when you don't have hookups. A navy shower is better than no shower .
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
spepi
Mansfield MA
Remove the filter and housing and all, fit the pipe together with the fittings from the filter housing, and get a new showerhead. I did this, and my trailer has so much pressure..it hurts...well, not really, but its like being home, except its a little smaller
DW, 2 Teen's, 2 Dogs
05 Chevy Trailblazer (I know...its small)
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Contol
2008 Rockwood 2701ss
Mikeyxx
Hamilton, Ontario
So what was the pressure before you guys changed the head/removed the regulator? Mine is so dismal that if I flip the showerhead so it's spraying up, it won't actually arch out of the head but instead creates a pool of water in the head with a 1/4 inch fountain...maybe.
Really really nasty.
canoe on top
Denver, CO, US
You didn't say if you were on the pump and FW tank or campground water. If you take the reducer out of the shower head, you will get more pressure but will use a lot more water. If you boondock you don't want to do that. How was the pressure in the other faucets? Mikeyxx are you talking aobut the pump or campground pressure. The shower head can become restricted from mineral buildup or, you might need a new pump.
ManInACan
Long Island
busch2fan wrote: Another vote for the Oxygenics shower head...
Do these shower heads have an on/off switch like the oem ones?
2005 Gulfstream Conquest 30 BHS.
2003 Dodge 2500 CTD HO 48RE
Me,Wifey,J.R.,Fido
fun2camp
PA
Oh it's def. not that, I tried that;(canuk camper wrote: This might sound silly, but typically these shower heads are adjustable, which means you can stop the flow of water without actually turning the taps off. Just by turning the dial/ring on the shower head you can reduce the pressure or stop the flow of water. My wife also mentioned low pressure one day and I looked at it and discovered this feature and with a slight turn of the dial we had resonable water pressure again. Just a thought.
Ron
robbie69
wauconda, il usa
DW complained alot about the pressure and getting shampoo/conditioner out of her hair while using the pump. i have seen here that alot of people restrict the shower head itself. i took off my shower head and with my trusty hot glue gun i put a drop of glue on every other hole. figured if it didn't help/work i could always remove the glue. DW says it helped so she's happy and so am i
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
Chuck&Gail
In the Colorado Mountains
IMO first remove stupid government mandated flow restricor. Usually between shower head and hose, just unscrew head from hose. Looks like a washer with a small hole. Throw it at nearest government official.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
