RV.Net Open Roads Forum: Travel Trailers: Wiring an inverter
Open Roads Forum  >  Travel Trailers  >  Vintage TT's
 > Wiring an inverter
Monkey #39
Victoria BC / Canada
Posted: 05/12/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
So I bought a small used inverter for our old TT. It's a 600W continous and 1000 watt peak inverter I wired it up. and we hooked up a very small coffee pot ( 600W ) and it blew both fuses?
My question is what size wire should I be running from the battery to the inverter?
MONKEY #39
2006 F150 SCREW LARIAT 1970 NOMAD 16ft "Under Construction"
2oldman
WA
Posted: 05/12/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
1000 watt peak @ 12v = 83 amps. Use a wire big enough to carry 83 amps. Charts all over the internet. I don't own a Vintage Travel Trailer but I know this to be true.
MegaDodge
Ontario, Canada
It was likely the fact that you hooked it up to a coffee pot that caused it to blow....a small coffee pot draws more than a thousand watts. a 600 watt inverter is for such low draw items as lights, TVs, DVD recorders....and laptops if it clean enough for laptops. The rule is to connect it as close as possible to the battery with heavy wire....I would look at the installation instructions to be sure but I would think it is calling for around 8 ga. 0r 6ga. wire. It's permissable to run a longer 120v. extension cord from the inverter,but the 12v. cables providing power to the inverter must be short. Also, be sure to place a fuse (again, check for instructions)in the positive line. It will call for something like a 120 amp fuse....you can get them at a good automotive store...
MegaDodge
Dodge CTD 1 ton. 5 speed.
2003 Everest 323P 5th wheel 13000 pounds ready to roll. .
"An honest man is the guy who does the right thing when nobody's looking"
smkettner
Vladivostok, Russia (temp)
Posted: 05/12/08 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Tripplite inverter wire chart.
I would size it for 100 amps so probably #2 wire.
