bbkb4winds
central ny
What is the procedure for filling the propane tank?? Could I expect that most propane fill stations could do this? I wanted to get some advice/knowledge before I get the tank filled (first time getting the tank filled, approx. 1/3 full now).
Thanks!!
Rollincool
Always Rollin
You pull up to the filling area, open up your little door, (where propane tank is), they connect the hose, they fill it, you pay, you're off.
Did I mention NO SMOKING?
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6349
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - Kā¢Hits 106.7
janstey
Glenwood, IA
And don't forget to turn off all flamed based propane appliances. Even though the main is shut off, there is still gas in the lines inside the coach.
JeffA and KimA
2003 Four Winds Chateau 31S Class C/Ford V10/with slide
2003 Jeep Liberty toad, all 4 down w/brake buddy
trnfla
Tampa
I believe the question was do you have to go to a special LP station or can they be filled by any location that fills LP tanks? I have the same ?
Have a great time camping,
Terry
Please say a Prayer for my 10 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
downtheroad
Tumbling Waters, Washington
Just a thought. Ask how they determine how much to charge you.
Most often we have been metered and charged by the gallon amount that was pumped
BUT:
We have also been charged by the tank size as if the tank were completely empty.. so, say we have a 30 gallon tank and only had 5 gallons pumped in, they still charged us for 30 gallons!
There was some small print at the station that we didn't read. Live and learn. I suspect that this "rip off" practice is not common, but ask up front anyway.
(has anyone else come across this practice for selling propane?)
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
bbkb4winds
central ny
I believe I read that the tank should not be filled greater than 80% to allow for expansion. It looks like there is a level gauge installed on the side of the tank that will leak LP as it reaches that level. Is that the 80% fill mark?? I want to be informed before I let someone start filling the tank.
Camper Ken
Oregon
Modern propane tanks have an OPD (overfill protection device) built in. This prevents them being filled past 81% capacity. The attendant filling the propane tanks knows what to do and how to fill it. Don't make a big deal out of this, it's a no brainer. If you're filling the non-removable tank on your motorhome, the only consideration is choosing a location where you can pull up next to the propane filling station.
2007 Winnebago Access 31c
(2006 Ford E450 chassis)
trnfla
Tampa
Camper Ken,
Thank you for a to the point answer.
Rollincool
Always Rollin
Camper Ken wrote: Don't make a big deal out of this, it's a no brainer. If you're filling the non-removable tank on your motorhome, the only consideration is choosing a location where you can pull up next to the propane filling station.
Amen.
ShapeShifter
Buffalo, NY
trnfla wrote: I believe the question was do you have to go to a special LP station or can they be filled by any location that fills LP tanks? I have the same ?
Almost any location that fills propane tanks should be able to do it. If they are a small place (like a pool store) that only does BBQ tanks, you may have issues. But larger dealers should be able to handle it.
downtheroad wrote: (has anyone else come across this practice for selling propane?)
So far, I've only run into this sales models at the small places that fill BBQ tanks. I've not seen it yet while filing the MH tank. But I do ask!
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
