RV.Net Open Roads Forum: Class A Motorhomes: Best Class-A gasser
 > Best Class-A gasser
SemperFiCop
Posted: 05/12/08 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
poker5150 wrote:
Thanks for the replies. Now....Ford or Chevy chassis? And why?
Ford is cheaper, more common...
poker5150
Ventura County
Posted: 05/12/08 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
So then you are saying Chevy is better? What tranny is in the Ford...is it the torqueshift?
2008 WW LE3305
2004 Ford F-350, 4X4, CC, SRW, 5-inch Pro Comp lift with 35 inch Pro Comp Extreme A/T's, 4-inch MBRP turbo back exhaust w/cat delete, SCT XCal-2, Autometer gauges, intake elbow, and some other mods
s & s
Michigan
Posted: 05/12/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Both chassis are good. Workhorse has an edge with their Allison 6 speed trans but the Ford has come a long way to close in. I drove both in the past few months and I actually preffered the Ford. It seemed quieter to me in two identical units. You can have a Ford vs Workhorse debate all night but you have to be the one to decide for yourself. Good Luck in whatever you decide.
Steve & Sally (S & S)
Houston & Hitee (Our Little Poms)
Heidi (Forever In Our Hearts and Never Forgotten)
1994 Fleetwood Bounder 32H F53/460 112K AND COUNTING
Toad Searching
bsinmich
Holland, MI
Posted: 05/12/08 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
I am very happy with my combination. The fit & finish on the MH is better than my home and I have the 5 speed on my WH chassis. They now use the 6 speed. Tge Allison Transmission would be the big reason for WH.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
OntMontana
Guelph, Ontario
Tiffin is going to the Ford Chassis for their largest Allegro Bays (gas version) in 2009. Don't know why but there does not seem to be a great deal of enthusiasm for the move among Tiffin gasser owners. The Ford set up in the 2008 Allegro uses the 5-speed Torq-Shift tranny.
We have the Workhorse chassis on our Allegro Bay and are very happy with it so far. Do not know whether it is "better" than a Ford ... have no experience with a Ford.
Bill & Ann
2007 Tiffin Phaeton 40QDH
2007 Jeep Liberty
Our "Cat Rescue Girls", Sadie and Aimee
tpharleyguy
So. Calif.
Posted: 05/12/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Mine.
2006 LaPalma
V-10/5 speed
Luv'n it
Johnny Hurryup
Tafton Pa.
Posted: 05/12/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
FORD!!!!! Why???? Because I'm a Ford man.
Johnny Hurryup
Tafton Pa.
Posted: 05/12/08 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'd rather push a Ford ,than drive a Chevy.
avidude
Posted: 05/12/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
To each his own...
I'd say Southwind or Adventurer.
Either Ford or WH just double check the CCC weight capacity.
Ted
'07 Bounder Diesel 38S
Cat C7 300hp, Allison 3000MH
Tow: '06 GMC Yukon
kmb1966
Houston
Posted: 05/12/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Perhaps your motorcycle could pull the gasser instead of the other way around?
