custom-cruiser
Boise Idaho
I have had my two Trojan T-105's awhile and finally collected the rest of the gear. This was intended to be a low budget install.
Inveter is a Xantrex Pro 1800 with remote faceplate and built in transfer switch. I chose to wire whole house knowing that would come with more operational responsibility but less hardware (no sub panel) and cost. The biggest inconvenience with this method is I have to unplug my converter (maybe i'll put in a wall switch?) I'm pretty handy around the shop but electrical is not my strong point so if something is grossly dangerous please let me know.
Xantrex Pro 1800 W/ remote panel and 250 amp push to trip circuit breaker (per instuctions)
30' of 12/3 stranded wire and 10' of 2/0 welding wire
Welding wire cut and crimped on connecters / 250 AMP breaker
Old cable from breaker box and new "IN" line to inverter
New "IN" and new "Out" from inverter
Inverter in front storage space
We will try this system out and see if it fits our needs then possibily modify later. Bigger converter ect.
edited 05/12/08 05:31pm by custom-cruiser *
2007 Suburban 2500 TV
2007 Avalanche
2007 WW FS2500 Billet
2007 WR450F
2007 TTR 230
2007 TTR 50
2007 Eagle 110 ATV (Hecho in China)
2003 TTR125
1985 Jeep CJ7
dedmiston
So Cal, USA
The Xantrex doesn't have a converter built in? So do you have to physically bypass the inverter when you run your gen?
It's a nice clean unit. It has a better look to it than the one we installed three or four years ago.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600
Toys:
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
- 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
custom-cruiser
Boise Idaho
It has a built in transfer switch but not a built in converter. The remote panel is kind of nice too. I picked up this refurbished unit(90 day warranty) for $200.00
derwud
Pasadena, CA
custom-cruiser wrote: It has a built in transfer switch but not a built in converter. The remote panel is kind of nice too. I picked up this refurbished unit(90 day warranty) for $200.00
From where?????
2005 Nissan Titan CC SE 4x4, 2006 Weekend Warrior FS2300
2 Quads, 2 Motorcycle and a '06 Rhino
1 Patient Wife, 1 Crazy child, 1 sweet baby.
RIP Bubba and Toby, we love you.
custom-cruiser
Boise Idaho
Xantrex XM 1800 for cheap
jackxclan
bakersfield
Thats the same unit I have but I only use it for a couple of things so I run it off of 2 extention cords. Do you have to unplug shore line and plug in inverter line and reverse to go to Gen. power?
red GMC gazzer
red WW fsc 28 tiki hauler
red 400 ex
black 250ex
red 400ex
red 250ex
red KW heavy iron hauler
HOOLIGAN # 385
custom-cruiser
Boise Idaho
in the second to last photo it shows ready to run the Gen.(both plugs in). To run inverter I have to unplug the small black plug to the converter(you can still run the Gen but no battery charge). for shore power the big plug comes out to hook to shore power and it runs through the inverter and back to the breaker box
derwud
Pasadena, CA
jackxclan wrote: Thats the same unit I have but I only use it for a couple of things so I run it off of 2 extention cords. Do you have to unplug shore line and plug in inverter line and reverse to go to Gen. power?
You should only have to unplug for shore power, and if you are hooked up to shore power, you don't have to use the inverter or Genny...
I've alreay installed a Transfer switch after looking at this, I don't need it!!!!
JSGrewal
Simi Valley, CA
How far is the breaker from the battery?
I have the smaller unit, XM1000 wired to just the TV outlets. Works great!
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6
jbbrick
Northern Calif
I have the same setup, the XM1800 and two 6v's. But I agonized over how to do the wiring and researched all I could find on the net. My previous MH was hooked up just like yours and I put a switch on the outlet that the converter connected to. That way all I did was physically plug in the system to the inverter and switch off the converter.
On my new one I rewired the whole house panel, split out all the plug circuits and installed a sub panel with 4 circuits to hot up all the plugs, and the built-in isolator automatically disconnects the system when plugged in to shore power. Seems to work fine, took me a few days to figure out and wire but I think its a better system. I love the sub panel that comes with the Xantrex giving constant voltage readings.
Your setup should work just fine and it does a good job with the microwave, etc.
