jackxclan
bakersfield
derwud wrote: jackxclan wrote: Thats the same unit I have but I only use it for a couple of things so I run it off of 2 extention cords. Do you have to unplug shore line and plug in inverter line and reverse to go to Gen. power?
You should only have to unplug for shore power, and if you are hooked up to shore power, you don't have to use the inverter or Genny...
I've alreay installed a Transfer switch after looking at this, I don't need it!!!!
I knew that, but just figured this out, this is a real simple hook up. I'm gonna give some thought to do this to mine. Just have to remember to cut power to the charger.
Gun metal gray 07 new body style 3500 diesel crew cab 4x4 dually
red WW fsc 28 tiki hauler
red 400 ex
black 250ex
red 400ex
red 250ex
red KW heavy iron hauler
HOOLIGAN # 385
derwud
Pasadena, CA
jackxclan wrote: derwud wrote: jackxclan wrote: Thats the same unit I have but I only use it for a couple of things so I run it off of 2 extention cords. Do you have to unplug shore line and plug in inverter line and reverse to go to Gen. power?
What I can do is run the Converter off the Shore/Generator side of the transfer switch. I'll just run it off it's own circut breaker.
2005 Nissan Titan CC SE 4x4, 2006 Weekend Warrior FS2300
2 Quads, 2 Motorcycle and a '06 Rhino
1 Patient Wife, 1 Crazy child, 1 sweet baby.
RIP Bubba and Toby, we love you.
jackxclan
bakersfield
Any down side to running the whole trailer off the inverter?
derwud
Pasadena, CA
You need to make sure the Refer is on Gas... And the converter is turned off.
deviousracing
mesa, az
jackxclan wrote: Any down side to running the whole trailer off the inverter?
i am wondering the same thing, i know all the appliances have phantom power they draw, wasting power from the batteries... how do you turn the converter off?
06 Chevrolet 2500hd LT 4x4 D/A CC/SB
09 Forest River Shockwave 38SP fully loaded
Tatum sandrail, polaris RZR
jsalazar310
Carson, CA
running the microwave can drain the batts pretty quickly!
2004 GMC Sierra 2500HD 4x4 Duramax/Allison
2007 WW FSW2800 Billet Edi.
derwud
Pasadena, CA
deviousracing wrote: jackxclan wrote: Any down side to running the whole trailer off the inverter?
That's what we are tying to figure out.
I wonder if you can pick up a signal source from the inverter that it's on and use a relay to cut power to the converter?
smkettner
My converter and fridge (120 volt heater) are tied together onto one breaker that could be switched off when boondocking.
custom-cruiser
Boise Idaho
This inverter has a remote panel with an ON/OFF button. You can also switch from three different read outs 1. input voltage 2. input current 3. output power
When I store the Hauler for any lenghth of time I will hit the trip switch on the circuit breaker and be totally disconnected.
An automatic switch would be great to turn off the converter if someone comes up with one let us all know!
2007 Suburban 2500 TV
2007 Avalanche
2007 WW FS2500 Billet
2007 WR450F
2007 TTR 230
2007 TTR 50
2007 Eagle 110 ATV (Hecho in China)
2003 TTR125
1985 Jeep CJ7
juzplanekrazy
Huntington Beach Ca.
I cut the converter/ charger completely out of my system.
last
edited 05/25/08 07:55am by juzplanekrazy *
View edit history
