RV.Net Open Roads Forum: Class C Motorhomes: 2007 C5500 endura fuse panel location?
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > 2007 C5500 endura fuse panel location?
belopar1
ga
Posted: 05/13/08 04:34am Link  |  Quote  |  Print  |  Notify Moderator
Can someone tell me if there is another fuse panel other than the 2 under the hood on the passenger side firewall? my 12 volt outlets have stopped working and i think it is just a fuse but i cannot find it.
Thanks
ronfisherman
SE Michigan
Posted: 05/13/08 05:00am Link  |  Quote  |  Print  |  Notify Moderator
There is another fuse panel under passenger side airbag/glove compartment.
Saf-TTE tire monitor
belopar1
ga
Posted: 05/13/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
az99
N.Y.
Posted: 05/13/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
You will need a 10MM nut driver or socket with an extension to remove the lower dash panel to get at the fuses. Nice design Chevy.
mfa
Posted: 05/13/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you are talking about 12V outlets in your coach body rather than those in the chassis cab, my guess would be they are powered by your coach battery and go through a fuse box in your coach, not the ones in the C5500.
My 2006 Gulf Stream C5500 Ultra, which is very similar to their Endura, has a 12V fuse panel near floor-level below the fridge. It uses standard automotive fuses.
