RV.Net Open Roads Forum: Draining fresh water tank on Lance is incredibly slow
 > Draining fresh water tank on Lance is incredibly slow
EEWally
Montana - The Last Best Place
Posted: 05/13/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Draining the freshwater water tank (Lance Sq. 5000, spigot near left-side bumper) of our new (used) Lance takes forever. I opened the spigot last night when the tank read 2/3 full and it is 1/3 full this morning. I loosened the fill cap and opened the faucets. Am I missing something? Or is there something clogging in the line? Does it have to somehow drain through the pump?
I used to fill the coffee pot from the outside drain spigot of our old Beaver camper (no electric pump) and I would like to do the same with the Lance.
Thanks!!
1997 Lance Squire 5000, 10-foot camper
2001 Dodge Ram, Cummins, Ext. Cab, 2WD
2oldman
WA
Posted: 05/13/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I've found the fastest way is to open a few faucets and drain it out the gray tank.
jmcgsd
San Diego, CA
Posted: 05/13/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like it's slower than it should be. Mine (40 Gal) drains in about 45 minutes.
'05 Lance 981Max Loaded
'91 F350 Dually 2WD CC 460 Gasser
AirLift Bags, Reese Titan hitch, Rancho 9000X
Banks TransCommand
'87 Suzuki Samurai Toad
1 DW
My Camping Web Page
nwjetboat
Eugene, Or
Posted: 05/13/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
My AF990 was also a slow drainer, until I took the drain valve apart and found some leftover plastic shavings from the tank clogging the valve. Just might be what your experiencing..
2003 Dodge 2500 CTD
2005 AF990
Axle
Lake Powell
Posted: 05/13/08 08:41am Link  |  Quote  |  Print  |  Notify Moderator
The Tygon tubing between the water tank and the drain valve could be pinched somewhere. Possibly a plywood wall or other interior piece of wood is on top of the drain tubing. If you can get access to move the tubing you might be able to feel if it is jammed against something or pinched somehwere.
2007 Chevy Ext. Cab 4x4 SB D/A
2005 Outfitter Apex 8
Torklift, Ride Rite Air Bags
1993 Sea Ray 24' Open Bow
dandba
Denver, CO
Posted: 05/13/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you might have some blockage. A typical cause of this could be mold growth. You might consider sanitizing the fresh water system and run it through the spigot to clean it out. A common method is fill your fresh water about half, then mix well a 1/2 cup bleach with a gallon of water, then put that in the freshwater tank. Top off the rest of the tank. Drive it around the block a couple times, and let sit overnight.
Run water through all faucets and in this case let everything go out the spigot for max cleaning. Refill and flush a couple times until you no longer smell bleach. You can also put a little baking soda to help take the smell away, but not necessary. Good luck and hope that helps!
2002 F250 4X4 Crew Cab
2002 Lance 815
2001 Crestliner Fish Hawk 1650
DonCurley
La Sal, Utah
Posted: 05/13/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
My Outfitter Apex 8 (with a 44 gallon fresh water tank) also takes forever to drain through the small outside spigot. I have heard from others that this is not an uncommon occurrence with the small diameter drain line and small orifice drain valve that are typically used. After I checked my valve for any debris (there wasn't any), I finally gave up on that method. I now just use the water pump to pump the fresh water tank contents into the kitchen and bathroom sinks, then into the gray water tank, and I then subsequently open the very large diameter gray water tank dump valve and dump into a culvert ditch/pipe on the side of my property. What used to take the better part of a day now only takes a half-hour or so to do, start-to-finish.
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo M/T's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
Frank_EP
Fountain Valley, CA
Posted: 05/13/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Open the low point drain.
Then turn on the outside shower.
With both the water pump and the drain running, it empties fairly
quickly.
2003 Lance 1071 maxed out plus 200 watts PV, accumulator and bottle opener
2004 Chevy 2500HD Duramax 167", Hellwig, Reese Titan, Reese Front, LineX, AirLift, bed mat, Rancho9000, Rickson 19.5" Eliminators with Mich 225/70 XDE M/S
KF6JGX; 5W on Yaesu FT530
Mooney
Santa Barbara, Ca
Posted: 05/13/08 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like something is wrong. Most drains are typically small and drain slow, but I have never not had one empty over night. Maybe you have a kink or something crushing the tube somewhere.
'08 Ford F550, Lariat, Link Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'05 Lance to-the-Max 1181.
'09 Host Everest (on order) expected BOD 11/05/08
Local Music
Ramblin' Ralph
All around California
Posted: 05/13/08 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
My '01 Lance 845 has a "gravity feed" drain on the back that would take forever to drain the 33 gallon fresh water tank. However, it also has 2 clear plastic tubes in the compartment with the waste tank drain valve handles. One for the cold water, one for the hot. When the valves on the tubes are opened, then the pump runs and will empty the tank fairly quickly. Be sure and put the ends of the tubes outside.
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Firestone Air Bags, 125 watt solar
1970 Martin D18 Guitar
My RV Travels Webpage and Campsite Map
