RV.Net Open Roads Forum: Hybrid Travel Trailers: tire cracking
Open Roads Forum  >  Hybrid Travel Trailers
 > tire cracking
JPBNICE
toronto
Posted: 05/13/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2006 travelstar sb I just picked up and noticed the tire have lots of cracking on side walls and into tread should the dealship replace???
Bobj616
Texarkana,TX
Posted: 05/13/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
If this was sold as New(untitled) I would think that they should replace them. If it was used then you are probably going to have to buy your own tires but it never hurts to ask.This is just my opinion and will not hold up in court My 2005 Roo still has the original tires and I haven't seen any cracking. All I have done is use a tire spray(something like armor all).I don't cover them and they get a lot of sun where I park my trailer. A few years back there were some pretty shoddy tires put on some of the trailers(by all manufacturers) I happened to luck out and get the better grade of the same tire brand that people were having trouble with(Carlisle).
One way or another I would get those cracked tires replaced.Bob
2005 Rockwood Roo 21SS
2008 Ford F150 S-Crew 5.4L
Yamaha EF2800i generator
ethierbach
Ann Arbor, MI
Posted: 05/13/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
It's a known problem with the tires Starcraft used on some '06 and '07 trailers. (I have an '07 XP 18RB.) When I picked mine up from storage in March, they looked like they had been sitting in the sun for years. I wouldn't tow it 30 miles to the dealer, they were so bad.
I called Starcraft, who referred me to the tire company. They in turn got me in touch with a local dealer, who replaced them under warranty. They actually offered an upgrade to the radial version of the tire, which has much better reliability according to the dealer. They charged me the difference between the bias-ply model and the radial model, $12 per tire. Very reasonable of them and well worth it, IMO. They replaced all three tires.
Call Starcraft and see what they will do for you.
Gale Hawkins
Murray, KY
Posted: 05/13/08 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
If the cracks are not deep it could just be normal. It is not cracks that is always the concern but how deep they are. Since trailer tires are often questionable remember they could have been run low at some point as well.
JPBNICE
toronto
Posted: 05/14/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
the tires only have maybe 1000 km on them some of the cracks are half around the tire a couple mm thick. The dealership referred me to the tire dealer who now I am waiting to here back from. Too bad I have reservation this up coming weekend. Looks like drive way camping.
llowllms
Crawford, Tn. USA
Posted: 05/15/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Put a push on the dealer to get new tires. Tell them you didn't buy your rig to leave it parked at home and make sure that you let them know that you have reservations this week end and of any penalties you will incur if you have to cancel.
Chuck_S
Broadview Hts, OH, USA
Posted: 05/15/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
RV Tire Guide
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
SLSAntigua
Pennsylvania
Posted: 05/16/08 10:42am Link  |  Quote  |  Print  |  Notify Moderator
My tires don't look like they are cracking but I have noticed that the lettering on the sidewalls look like they were inserted too deep and the rubber overlaps around them. difficult to explain. Have to upload a picture. anyone else seen this or have this? is this bad Keep forgetting to ask the dealer.
Steve, DW, 2 DDs
2006 Starcraft Antigua 215SSO
2008 GMC Envoy SLT
Voyager Brake, Reese WDH and sway control
TandA-n-Mac
new jersey
Posted: 05/17/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
tires are your weakest link. get rid of them either by dealer or yourself. check when they were made usually on backside of tire( 2406 means tire was made the 24th week in 2006) also these tire shine products with petroliem will cause this. you can not afford to play around with tires.
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
Padlin
W. Ma.
Posted: 05/18/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are cracking too, I'll make some calls this week. Found a set of Coopers locally that I'll go with if I have to pay for them, we'll se what the manufacturer says...
Bob & Deb
W Ma.
04 GMC 1500 4X4, 5.3L
06 Starcraft 18SB
 > tire cracking
