tibba
massachusetts
I just bought a 2008 Jayco Jay Feather 213. Very nice! But, I'm worried how the awning will react in rain. There is no way to tip it to one side for run off. Does anyone have one of these and have any experience or suggestions?
skipnchar
Topeka Kansas USA
I wasn't aware that Jayco made an electric awning. Check the brand and you'll probably find it's an aftermarket and knowing the brand would help in answering. All of the electrics I've seen CAN be compensated manually but you'd need to disable the automatic deploy feature.
Gosple
Henderson NC
I have a jayco 32bhds it has a electric awning made by carefree. It will dump rain automatically if needed. Mine has enough slope that it should not hold water.
Aceal
BC
Don't worry about the awning. There are 2 gas shocks on the unit. One in each arm. When and if there is rain the awning and it gets heavy it will pull the unit and drain to one side.
5weekendwarriors
iowa
I was wondering the same on my new keystone sprinter. I'm not even sure what kind of awning it is, but I was told there is a gas shock that will dump the water. I was wondering also if there is a wind sensor on mine. I guess that would pretty much eliminate awning lights if it does. Seems stupid I know little about the awning, but my first thought when I seen it was electric was that I could now make my wife get out of bed at 3 in the morning to roll it up when it's storming. I didn't think of anything else.
- 2008 Dodge Ram 3500 Megacab Dually 6.7 CTD 68RFE 6 Speed Auto 3.73's
- 2009 Keystone Sprinter 311BHS
- Equalizer 12000# Hitch
- 2007 Jeep Commander
- 2004 Lowe Suncruiser 20' Pontoon
- Gone But Not Forgotten
- 2006 McKenzie Starwood 30CKS:2001 Jayco Eagle 304BH
subourbon
Huntsville, AL
Most of the new Jayco trailers come with the Carefree Electric Awning. It will dump water to one side when the weight of water overcomes the gas shock. Unless you have a very expensive electric awning you will not have a wind sensor on your Jayco Awning. My awning has 2 gas shocks and will dump water to either side.
Happy Camping
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Prodigy Brake Control
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
