RlphKnndy496
Sedro-Woolley , WA.
has anyone seen or done this???....or did i just invent the wheel??...ok i've seen spare tires on the rear bumper...and i've seen them on the bottom of the fifth wheel between front jacks..and i've seen..peaple remove it off the back bumper to make room for a rack...so they throw it in the bed of the truck>>>>>>>>>>>>>>>>>>>>>
So this is my idea...i was looking under my TV...and in the rear my spare is under my bed like all TV...on a winch cable...16" wheel and tire...the cable is very long...long enuff to reach the ground....couldn't I/WE stack two tires together...truck and trailer tire...lower the cable to the ground...and hook onto the lower wheel...and then crank both spares up under the TV at the same time???the first tire you can never see...unless you climb under the truck...the secound tire will only stick down anothe 7 inches...is this a great idea or what??
Cox89XJ
Tennessee
I'll be watching this thread. My Cougar has the extendable rear bumper. The spare was on it, but carrying bicycles I figured it to be to much weight. So I put my spare in front of the fifth wheel hitch between it and the tool box.
robbins
Sonora, Ca
I have a rear storage, that is where the spare was mounted. It was taking up to much room, so I bought a foldable rear bumper mount. So far, works for me.
Sounds like you have a pretty good idea. Like to know how it works out.
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
pritch272
Martinez, GA
Hmmm, just another 7".... I'd be concerned about hitting the ground going over dips, etc, and if the cable is actually strong enough for 2. I carry the spare rib in the truck between the hitch and the tailgate as it's too heavy for the bumper.
Retired US Army
2000 Ford F250 SD 7.3 PSD, Firestone Ride-Rite⢠air springs
2007 Keystone Laredo 29RL, Doran Pressure Pro and Metal Tire Valves, 16" Michelin XPS Ribs, Dirt Devil CV950 Central Vacuum, 2000W AllPower (Honda Clone), 4000/3500W Champion C46540
tom_kat
way upstate new york/lake george area
I would be worried about the set up not being strong enought to carry two, from time to time you here of them haveing the cable break with just one tire under there,i have seen a mod made of steel where the tires were between the frame rails and slid in from the rear and steel straps and frame work held them up so they would not fall out and a bar across the back to keep them in that could be locked so they could not be stolen and it worked ,kind of like the tire carriers on commerical trailers.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
Vulcaneer
Northern New England
This is a great idea. But, I would just be very careful of the strength of the whole mechanism. Not only the cable. If anything (Ratchet, pulleys, brackets, etc.) in the mechanism fails, you could drop both tires. You can likely get a feel for the strain you put on the mechanism, when you try to lift the two tires, with the little hand crank. It would be a lot of weight. Might advise you try to add on a 'fail safe' strap of some sort, just in case.
If something fails and both tires drop on the road, they'll bounce around. And could cause major damage to the truck, and/or the trailer. Not to mention the safety and welfare of anybody on the road. Including you and your family.
To me it is not worth the risk. Especially when you are using the spare tire lifting equipment, in a manner that it was not designed.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
SEE RV.net Classified for Vette Description
rvnutts
Hampton, Arkansas
I guess we don't carry much stuff. Ours is in the basement.
Lynn
Brian and Lynn
11 yr. old son Sam
2005 Chevy Silverado Diesel Crewcab 3/4 Ton
07 Outback Sydney Edition 32FRLDS
smkettner
I made new brackets to mount the spare so it effectively sits on top of the rear bumper instead of the mount that hangs it way out to the rear.
Cabriolet86
Rochester, MN
My GMC truck has the spare tire mounted under the bed using a cable/winch system to lower it to the ground. (in fact, my wife's Chrysler Pacifica has the same sort of system). I've been meaning to go to a junkyard and take the setup off of a junked car, and then mount it under my camper in a place where there is some spare room.
BigJon05
Ripon
I have a cinch cable lock made by master (like a bike cable lock) that I cinch around my spare plus a bar under the spare. If you have one of those aound both it might help with the weight...
05 Eclipse Attitude 26'FSAK
03 F350 PSD longbed, 6" lift BFG 35
08 Polaris RZR
07 Can-am Outlander 650 MAX XT
2 Can-am DS650 00/01
1 TTR 90
1 Redcat 110
1 Unison 50
1 Honda XR50
