RV.Net Open Roads Forum: Travel Trailers: 2008 Starcraft 3612
 > 2008 Starcraft 3612
edovando
So Cal
Posted: 05/14/08 02:00am Link  |  Quote  |  Print  |  Notify Moderator
I purchased the trailer last year and have taken it out twice. Two questions.
1. Is it possible to get a roof rack on the trailer. I would like to carry 2 bikes or a canoe on top. Can I do this without ruining the warranty?
2. I believe the drain location was not properly thought out. It is to low to get a small portable tank under it. Any ideas on how to "connect" a portable tank.
LAdams
Northern Illinois
Posted: 05/14/08 05:56am Link  |  Quote  |  Print  |  Notify Moderator
If your dealer does the roof rack, I would think you would maintain warranty coverage..
Regarding the portable tank, I assume you mean a "Blue Tote or "Blue Boy" for gray and/or black water in addition to your holding tanks...
I had a similar situation on my last trailer and I used an extra SurFlo pump I had to pump the gray water to the Blue tote... I used one of those 3' dump camps with the hose fitting on it...
They say a picture is worth a thousand words so below are a few thousand more words on the subject
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
edovando
So Cal
Posted: 05/14/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
Great solution, the problem is the Starcraft Travel Trailer doesn't have a holding tank. It is a straight drain!
meriflower1985
Twin Cities, MN
Posted: 05/14/08 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
The Starcraft 3612 is a popup not a TT. You may receive a better response from the Folding Trailer forum.
edovando
So Cal
Posted: 05/14/08 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, hadn't noticed I posted in the wrong forum :-)
