hasheel
Durham,NC
What does anyone think of a pair of scissor jacks on the rear of my 31foot class C for leveling and stabilizing. I'm thinking of the 24" BAL model
2008 Tioga Ranger 31 W
02 Suzuki XL-7 toad
BrakeBuddy
ramzfam
Appomattox, Va
I have two in the rear and one in the front. They do a fair job of stabilizing but don't provide more than a few inches of leveling. Any more than that requires you pull out the blocks.
Have RV....Will Travel
2007 Forest River Sunseeker 2860 LTD
2000 Jeep Wrangler Sahara
oldham
Cameron, NC
Same with my BAL QTG system. Makes a great stabilizer but cannot be used for leveling much. QTG is real fast to engage. Scissor jacks are a lot cheaper though.
Jack & Marie
Good Sam Life Members
Sandhills Good Sam Chapter
Amateur Radio -K4FRU-
murffdog
Poughkeepsie, NY
I have them on my 31' and they work great although I must admit, when the wife and I travel alone, I don't bother with them. You will notice some movement mostly at night but we don't care.
fisher60
Plant City, Florida
I have them front & rear. If you're only a few inches out of level, sure beats using the blocks
'01 Dutchman Express 28A, Master Tow, '07 Tuscon, '05 Honda VTX 1300
jojolou
S. E. Michigan
When we had our 31' class C, I bolted 2 scissor jacks on the rear and I carried 2 more in a storage bay. I would first level the coach using Lynx Levelers if needed and then crank down the rear scissor jacks to be used as stabilizers. The 2 extra ones would be placed under the frame on each side, one under the entry door and the other opposite to it. It stopped most of the movement and made the coach more stable. It was most noticeable when someone entered or left the coach, no more of that annoying rocking motion!
Lou
Lou
2008 Allegro Bay 35 TSB W-25.5
Leewhiz
Johnstown, NY
I have regular 5000 lb rated scissor jacks on my class C and can do a fair amount of leveling. They are mounted to the frame just behind the wheels. I use an inexpensive impact wrench with 1/2 extension to raise the mh. Works pretty good for me.
Lee
Gene in NE
Omaha, NE
hasheel - As some have mentioned, do not use scissor jacks to level your motorhome. A small amount (say 1-2") might work, rather use them for stabilizing. The reason being you could bend or twist the frame unless you place them like "Leewhiz" has done. I would try getting the jack as close to the point where the springs meet the frame.
2002 Trail-Lite B Plus 211-S w/5.7 Chevy
Gene
