Bamabound
Alabama
So how do you all clean the A/C without getting on your roof?
tom_kat
way upstate new york/lake george area
you dont,the cover has to come off to do it so you have to go on the roof.you can clean some and change filters from the inside,the roof portion collects a lot of dirt and leaves and bees nest sometimes.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
mainetom
Maine, near Augusta
tom_kat's right, and I'm not looking forward to going up there (it's an age thing), but when the time comes I have this bookmarked. Any other helpful links are invited.
Dave H M
IL
bama
I wuldn't unless here seems to be a performance problem.
I ran my last one for eight years without even loking at it. I did have to clean the inside filter a lot though.
C Schomer
Buckeye, Az.
The condensor coil gets loaded up on the inside where you can't see it so I pull the cover and hose it out good every couple of years. Craig
Roy T
Dodge City, Kansas
My grandson, when anything on the roof needs done.
javaseuf
Southern Cal
The evaporator coil inside the RV in the ceiling plenumn also needs periodic cleaning.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Bamabound
Alabama
Thanks, I was just making sure. Our a/c froze up the other night which is unusual this time of year. My son can climb up and do it.
tlcombs
Atlanta, GA
When you say froze up, I am assuming icing up. When that happens, typically it is an airflow restriction (across coils) problem. Sounds like a good cleaning would be necessary! Good Luck!
2006 Cherokee Lite 28DD
2006 GMC Z71 4-Door, 5.3 V8, 3.73
Prodigy Controller
Eaz-Lift ProStar WD
javaseuf
Southern Cal
Yes and it's caused by insufficient air flow across the inside evaporator coil, not the condensor coil out on the roof.
Usually dirt blocking the fins on the coil.
