RV.Net Open Roads Forum: Travel Trailers: thedford toilet keeps running
 > thedford toilet keeps running
PaulandMonica
Victoria B.C
Posted: 05/14/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
We have a thedford Aqua Magic toilet in our 21ft trail Cruiser. Every once in a while the water continous to trickle in after flushing and nearly caused it to overflow a couple of times.
It seems nearly impossible to reach behind it to replace the valve if that is needed. We were hoping someone had done this before and could give us some guidance as to what to do. Thanks for any help you may be able to give us.
rvsatek
AZ, USA
Posted: 05/14/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
You need to remove the toilet to replace the valve. It is easy and the valve comes with instructions.
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
whitejd
Deer Park, TX - USA
Posted: 05/16/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Before you remove the toilet try this. I had the same problem with my toilet and I used WD-40 and it solved the problem. Use the small tube with the WD-40 and spray around and behind the flush handle and follow the water line to the back of the toilet and spray that area that is where the valve is....Good luck
John D. White
Retired DPVFD Firefighter/EMT-P
Mean Ass wife Karen
Kids grown and gone
One beutiful granddaughter
Dog went with kids
the wood tinker
Lake Elsinore, So. California
Posted: 05/16/08 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
Did the same thing in our old TT. Worked great.R-Vision product too.
2008 F250 SD 4.10 gears and HD towing package.
2008 299BHS Tango
Jerry & Sharon
Bindi & Cody....the furry kids
