I purchased the trailer last year and have taken it out twice. Two questions.
1. Is it possible to get a roof rack on the trailer. I would like to carry 2 bikes or a canoe on top. Can I do this without ruining the warranty?
2. I believe the drain location was not properly thought out. It is to low to get a small portable tank under it. Any ideas on how to "connect" a portable tank.
I also have a 3612 but dry camp out hunting and just run the hose out 30ft, I do not understand why you could not hook up the hose and drain into the tank, unless you are talking about pushing the tank under the trailer, which is why I had, mine raised 4 inches.
As far as the roof rack, I would contact your dealer, as he will be the one that will correct any warranty issues or call Starcraft direct.
pojv wrote: I also have a 3612 but dry camp out hunting and just run the hose out 30ft, I do not understand why you could not hook up the hose and drain into the tank, unless you are talking about pushing the tank under the trailer, which is why I had, mine raised 4 inches.
If you don't mind me asking how much did you pay for the raise, where'd you get it done at? Does it tow differently? I asked the dealer about raising it, they told me to go to a muffler shop and have them remove the axle and weld on a 4 inch extension.
edovando,
Sorry for the delay, as I was on a business trip. The dealer had this done prior to us taking delivery of the unit, and there was a 250.00 cost for it.
I never towed the unit prior to the lift but have not had any issues with towing. The lift does make it nice when going off the beaten path.
