RV.Net Open Roads Forum: Folding Trailers: Starcraft 3612
 > Starcraft 3612
edovando
So Cal
Posted: 05/14/08 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased the trailer last year and have taken it out twice. Two questions.
1. Is it possible to get a roof rack on the trailer. I would like to carry 2 bikes or a canoe on top. Can I do this without ruining the warranty?
2. I believe the drain location was not properly thought out. It is to low to get a small portable tank under it. Any ideas on how to "connect" a portable tank.
Accidently posted in TT forum originally.
pojv
Arizona
Posted: 05/14/08 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
I also have a 3612 but dry camp out hunting and just run the hose out 30ft, I do not understand why you could not hook up the hose and drain into the tank, unless you are talking about pushing the tank under the trailer, which is why I had, mine raised 4 inches.
As far as the roof rack, I would contact your dealer, as he will be the one that will correct any warranty issues or call Starcraft direct.
07 Starcraft 3612 w/ 4 Inch Lift kit
05 Dodge Dakota 4X4
Polaris Hawkeye
Hornet28BHDS
Parker, PA
Posted: 05/14/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Call the dealer about the roof and see what he has to say.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
edovando
So Cal
Posted: 05/14/08 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't mind me asking how much did you pay for the raise, where'd you get it done at? Does it tow differently? I asked the dealer about raising it, they told me to go to a muffler shop and have them remove the axle and weld on a 4 inch extension.
pojv
Arizona
Posted: 05/16/08 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
edovando,
Sorry for the delay, as I was on a business trip. The dealer had this done prior to us taking delivery of the unit, and there was a 250.00 cost for it.
I never towed the unit prior to the lift but have not had any issues with towing. The lift does make it nice when going off the beaten path.
 > Starcraft 3612
