RV.Net Open Roads Forum: Fifth-Wheels: fifth wheel plug in
 > fifth wheel plug in
George H
Washington
Posted: 05/15/08 06:02am Link  |  Quote  |  Print  |  Notify Moderator
I've had plugs in the bed sidewall on my last 3 trucks, hauled everything from lumber to top soil without problems.
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
jlvtx1800
Buffalo
Posted: 05/15/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
in bed...very easy...use etrailer.com
- 2008 Ram Laramie MC 4x4 SRW 3500 CTD 6.7L 6 speed manual
- 2008 Jayco Eagle 345 BHS
FOREVER FREE
Manchester, TN
Posted: 05/15/08 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for in-bed. Socket sits under bed rail behind drivers side wheel well.
"BIG BOB" & DIANE:
Big Mac & Sarah (Retired Greyhounds)
2005 Prowler Regal AX6 365BSQS
2005 F-350 Lariat Crew Cab 4x4, DRW, 8'bed, 6.0 P/S Diesel,
Veterans, the reason we will always be "FOREVER FREE".
SUPPORT OUR TROOPS
Sagebrush Monitor
Cheyenne, WY
Posted: 05/15/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
In the bed -- driver's side in front of wheelwell so I can reach it when fiver is hooked up.
'05 F350 PSD CC SRW Timbrens -- '02 Keystone Cougar 295 EFS
Dennis Bham
Alabama
Posted: 05/15/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I thought I would install a connection in the bed until I used mine over the tailgate for a few thousand miles ... I have observed that in my application, it's less likely to get tangled with my SuperGlide if it goes back over the tailgate. The only thing it rubs is the top of my tailgate, and it has a plastic cap on it. I has not left any evidence of abrasion.
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
Chefd
Arizona
Posted: 05/15/08 07:54am Link  |  Quote  |  Print  |  Notify Moderator
My in bed plug is mounted just inside the tailgate flush with the bed. Does not get in the way of cargo and I can reach it (being short and fat) from the ground.
Chefd
TubaPete
Comstock Park, MI
Posted: 05/15/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
joshjack wrote:
That being said, all of my trucks have the plug in the bed in the driver side corner post next to the tailgate. I recommend that location. . .
J
Interesting you should recommend that. I just had my hitch installed in a new truck and that is where they put the plug. It looks good, but I wonder if I will catch stuff on it when loading the truck when I am not towing. I thought they were usually closer to the front.
Tuba Pete
paztruck
San Diego, CA
Posted: 05/15/08 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
I got the y-connector from a local RV store and installed the 7-pin in the bed just in front of the tire well but behind the fuel door on the outside. Was an easy fix hardest part was drilling a hole in my brand new truck. Very easy to plug and unplug trailer and no worry if the plug is dragging on the ground. The Y is a direct fit for fords.
2006 F250 Extended Cab, Long Bed, 6.0 PSD, Tow Package
2006 Keystone Springdale 242
Roy T
Dodge City, Kansas
Posted: 05/15/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have the plug in the bed inside the back pillar. Works great.
Betsy II
BC
Posted: 05/16/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
My bed is lineX sprayed, including over the top of the tailgate. I plug the 5er cable in to the connector at the center of the bumper. No issues with tangling, as I use a bungy to keep the cable in position as well. I have a superglide (4 years now) and there have never been any issues with it.
Roy
