RV.Net Open Roads Forum: Technology Corner: LCD tv's
 > LCD tv's
Bluegrowler
Paterson ,Washington
Posted: 05/14/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I want to install a LCD TV in our 5ver. Going to use a articulating wall mount. My concern is ,does the vibrations , bumps and bangs while traveling down the road damage these type of tvs?
Thank you Ron
JTMO
Novato, CA
Posted: 05/14/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
There are tons of them out there, go for it. No different than any other TV.
Extreme cold can be an issue.
Cedar Creek 27LRLS 7359 dry with extensive options/7700+ loaded.
2003 Expedition 5.4 FX4 with factory Tow 3.73 Bilstein shocks. GCVWR 14500, Tow rating with no cargo 8650
Equalizer Hitch, Prodigy, Barker Electric jack. Coachnet ERS
Rallies=8
My travel albums
maryshus
san antonio, texas
Posted: 05/14/08 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
there was another thread somewhere that said yes. So a search for it. We did not buy one because the thread said the vibes shorten the life of the LCD to about 5 years.
phredsee
Santa Clarita, Ca.
Posted: 05/14/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Recently installed an LCD TV in the bedroom. Thought about the identical same issue you are, I elected to remove the TV each time we travel. It's very simple to remove just a center bolt that connects the main TV mount to the arm. Pack it away under the dinette bench and no worries.
Fred C, Mary & 'Noah' (momma's boy)
SoCal
KC6THS (ham)
07 Coachmen Concord
07 Saturn Vue
MNtundraRet
Bloomington, MN
Posted: 05/15/08 06:42am Link  |  Quote  |  Print  |  Notify Moderator
LCD TV's are the best type to use for RV's. My 19" 720p HD television rides on the carpet under the dinette. I thought about using a mount, but settled on putting the tv on the dinette table. The tv is at eye-level, and much easier to watch, from either the couch, or dinette itself. I have been using it this way for two years now.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
daverich
Northwest Missouri
Posted: 05/15/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
I leave mine mounted. If I were going to take it down while traveling, I would put it on the bed or the couch. I don't see where placing it on the floor or any hard surface will protect against vibrations. What would the difference between the wall and the floor be?
If not comfortable, put it on the bed while going down the road. JMHO
Bluegrowler
Posted: 05/15/08 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input . Off to the TV store. Ron
Hurricaner
Hurricane Utah
Posted: 05/16/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Laptops use LCD screens and they take a beating. There is no problem with an LCD in the RV as long as it is secure. The temp limit is like -40 F.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Damon owners forum
bigjimcruising
Orange County, CA
Posted: 05/16/08 11:58am Link  |  Quote  |  Print  |  Notify Moderator
My camper came with the little 15 inch LCD TV mounted on the wall. I added a 26 inch LCD TV on an articulated wall mount about 6 months ago and love being able to see the TV now! I've had no problems with it and it's even been off roading in some pretty rough areas. Since it is a single arm wall mount I do tie the TV to the wall using some rope and a couple eye hooks. This keeps it from swinging around and hitting things and helps take some of the weight off the swing arm when traveling. So far so good! I did buy a cheap TV just in case it couldn't take it, I didn't want to buy a really expensive set in case it failed. But so far everything has worked out great with no problems at all.
2007 F450 4x4 Extended Cab, 6.0 PSD AT, 9ft Flatbed with 8ft boxes. Okanagan 117DBL, loaded. 13ft tall! Happy Trails!
MH4Two
Ickesburg, PA
Posted: 05/19/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Here is an example of an LCD TV mounted on an articulated mount in the bedroom of our Overland. We just did 5000 miles to Las Vegas and back and if it still works after the PA turnpike and I-70 in Indiana, it's good forever......
Don Sweger
* This post was edited 05/20/08 01:21pm by MH4Two *
Me, the DW, 2 dogs and more.
1998 Overland Larado, 41', one slide, 325 Cummins, '02 Jeep Liberty with SMI-Air Force 1.....
 > LCD tv's
