RV.Net Open Roads Forum: Beginning RVing: High Curb - Low Trailer issues
 > High Curb - Low Trailer issues
QCMan
Long Island, New York
Posted: 05/16/08 04:11am Link  |  Quote  |  Print  |  Notify Moderator
If you go to the skid wheels make sure that you realize that you are DECREASING the already low clearance. The decreased clearance will put even more weight on the back of the frame when it hits and will probably end up with you making the local truck and trailer frame shop very happy for your business as this would cause damage not covered by warranty. Just put boards across the dip and at the curb to make going up it easier (and without causing damage to the tires) and smoother.
2004 Starcraft Aruba 25RS, 2004 Dodge Dakota SLT. Just the two of us, 2 Jacks and a desire to roam!
troll3193
SouthWest, MI USA
Posted: 05/16/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
tupapi77 wrote:
Ditto use the skid wheels, that should solve your problem IMHO
be careful with the skid wheels. I did that on my previous TT. Caused a lot of flex in the frame where it wasn't intended. There is evidence of it all over the TT...
I dealt with this for a couple of years on the previous unit, then finally "flipped my axles" to raise the TT 5 inches...
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
tvman44
Southwest Louisiana
Posted: 05/16/08 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Put some boards in the low area, like 2 x 4's or 2 x 6's.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Canadian Karebear
Saint Albert Alberta
Posted: 05/16/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Okay, got the Skid wheels on order, and have put the planks on the curb - leaving early tomorrow morning so hopefully won't have any issues.
Thanks everyone!!
Mommy , Skyler , Sammy...the wonder dog
TV: 2000 Ford Explorer Sport 2dr 4WD
HTT: 2004 Jayco JayFeather 18ft Hybrid; Prodigy brake control (with Eaz-lift WD hitch)
See you around the campfire!!!!
Nature does nothing uselessly...
Charlie D.
Gonzales, La.
Posted: 05/16/08 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
As others have said, be very careful with the skid wheels. Sharp inclines that take advantage of the skid wheels could possibly over stress your frame.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
NHguy
NH
Posted: 05/16/08 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, you can reduce the amount of weight distribution to allow the tongue to drop a little, that raises the TT back end. Try adding one or two more links into tension, then when the tongue is a little lower you might be able to sneak up that slope without a lot of drama. Of course you can't completely remove the WD or the tongue will probably drag...
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
Hornet28BHDS
Parker, PA
Posted: 05/16/08 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Wood sounds like a better alternative!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
