choclabmom3
Wisconsin
HAVE A CATALINA FIFTHWHEEL WITH SUPER SLIDE OUT. WENT OUT TO PUSH THE SLIDEOUT OUT AND NOTHING HAPPENED. NO SOUND, NO MOVEMENT. TRIED THE OVERRIDE BUTTON AND NOTHING HAPPENED THERE.
HUSBAND GONE AND I COULD USE SOME HELP. BATTERIES ARE UP, ELECTRIC PLUGGED IN. IS THERE A FUSE OR SOMETHING THAT NEEDS TO BE CHECKED. HAS WORKED FINE EVERYTIME WE HAVE OPENED AND CLOSED IT.
THANKS FOR ANY ADVICE.
Ninebell
Bardstown,Ky
I assume it's an electric slide out if it is there are fuses for them my happen to be in the panel just below the breaker panel.Hopes this helps good luck.
Ninebell,the Wife,and Ginger the Shiz-zhu
2008 F-450 Lariat PSD,DRW,CC,LB,4X4
2007 Jayco Designer 34RLQS.
My Photo's
trnfla
Tampa
Do your lights work? If not check your main breaker or cut-off switch. If the lights work, you need to check the fuse pannel like stated above.
Good luck
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
choclabmom3
Wisconsin
THANKS FOR THE TWO IDEAS, I'LL TRY BOTH.
donn0128
Pronounced Ore-gun
Oh and please turn caps lock off. Around here caps is a sign of yelling.
Donn
woodburner
Mentor Ohio
donn0128 wrote: Oh and please turn caps lock off. Around here caps is a sign of yelling. Who cares?
http://www.everest-owners.com/
rhillx4
Huntington Beach ,CA
woodburner wrote: donn0128 wrote: Oh and please turn caps lock off. Around here caps is a sign of yelling. Who cares?
LOL! So true. But some will get offended...
2002 Dodge Ram 1500 Quad-Cab
2008 Jayco JayFlight 26BH
9452772
Schertz, TX
I care
M&R
Schertz, Tx
2001 Ford F-250, 7.3, auto, long bed, 4x4
Autometer guages, 4" MBRP exhaust, AFE STAGE 2 intake
285/75-R16 BFG, 4.10 gears
2004 Nomad 2805
ScottG
Bothell Wa.
9452772 wrote: woodburner wrote: donn0128 wrote: Oh and please turn caps lock off. Around here caps is a sign of yelling. Who cares?
I care
Thanks for caring
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
roscoe
Priveledged resident of the gorgeous hudson valley
I DON"T CARE!!!!!!!!!!!!!!!
