roscoe
Priveledged resident of the gorgeous hudson valley
[quote=choclabmom3]HAVE A CATALINA FIFTHWHEEL WITH SUPER SLIDE OUT. WENT OUT TO PUSH THE SLIDEOUT OUT AND NOTHING HAPPENED. NO SOUND, NO MOVEMENT. TRIED THE OVERRIDE BUTTON AND NOTHING HAPPENED THERE.
HUSBAND GONE AND I COULD USE SOME HELP. BATTERIES ARE UP, ELECTRIC PLUGGED IN. IS THERE A FUSE OR SOMETHING THAT NEEDS TO BE CHECKED. HAS WORKED FINE EVERYTIME WE HAVE OPENED AND CLOSED IT.
THANKS FOR ANY ADVICE.[/quote/]
HOW DID YOU MAKE OUT WITH THE SLIDE OUTS
Vulcaneer
Northern New England
You live in Wisconsin. If you want me to hear you in NH, YOU GOTTA YELL.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
9452772
Schertz, TX
I am sorry, I just noticed that you are all "Senior Members" and the only way you hear is to be YELLED AT
M&R
Schertz, Tx
2001 Ford F-250, 7.3, auto, long bed, 4x4
Autometer guages, 4" MBRP exhaust, AFE STAGE 2 intake
285/75-R16 BFG, 4.10 gears
2004 Nomad 2805
Betsy II
BC
That's why I check this site out, for all the friendly banter.
Seriously though, there could be a separate fusible link near the battery as the motor may be direct wired due to its high current draw. This is the configuration on my 5er.
Roy
jdog
Some Place
woodburner wrote: donn0128 wrote: Oh and please turn caps lock off. Around here caps is a sign of yelling. Who cares?  That's right, who cares. Big deal, her caps where on. I didn't hear any yelling!
jdog
Some Place
Easy there roscoe, your yelling,I think.
Crodad
Lafayette, LA
ScottG wrote: 9452772 wrote: woodburner wrote: donn0128 wrote: Oh and please turn caps lock off. Around here caps is a sign of yelling. Who cares?
I care
Thanks for caring
I care also. Caps lock are much harder to read. Most of the time I don't even read them. and since people don't like it, this thread has turned away from the op. Turn your caps lock off and avoid this from happening. simple.
2008 F-250 PSD 4x2 Lariat
2005 Keystone Laredo 29RK
CD
Dallas
SOME OF US ARE BLIND THE CAPS HELP
shadoow
South Texas
in my fiver, there's a master switch for the slide that has to be on for the switch that moves the slide in/out to work.
CAN YOU HEAR ME NOW ???? (sorry, just had to do that...)
KZ 33P Toyhauler
2008 GMC 2500HD D/A
2006 Ultraclassic
1978 FLH
M GO BLUE
Southgate, MI
DITTO
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS
Built-In Onan 5500W generator
