RV.Net Open Roads Forum: Owners of CRV 05-06 w/ US Gear Towbrake
Search only in Dinghy Towing
 > Owners of CRV 05-06 w/ US Gear Towbrake
2Cats- Trek'n
Beaverton, OR
Posted: 05/15/08 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'm installing the the US Gear towbrake, and want to know the location that others used for the solenoid that operates the brakes??
Thanks,
Rodger
03 Safari Trek
06 Honda CRV-SE
othertonka
Stockton, CA
Posted: 05/15/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
My CRV is a 2002 and I put the solinoid under the drivers seat at about a 45 degree angle, ran the cable under the left edge of the carpet and then under the carpet over to the center so it ligned up with the brake pedal. I mounted the solinoid on a piece of plywood,slid it in place and then fastened the plywood to the floor.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
zoondoggie
Napa
Posted: 05/15/08 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Under the front drivers seat. Ran the brake wire under the Carpet. The wires are in the black door channel on the driver side along the floor.
Cheers
"If you don't know where you're going, you'll wind up somewhere else"
Yogi Berra
KraftCrew
Redmond, WA
Posted: 05/20/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I just finished installing the US Gear brake on our 2006 CR-V. I mounted the solenoid on the passenger firewall and routed the cable under the heater ducts to the driver side. The solenoid is covered by the passenger carpet and you don't even see it.
