RV.Net Open Roads Forum: Tech Issues: Help...Dometic refer not cooling at all
 > Help...Dometic refer not cooling at all
livingaboard
Everett wa
Posted: 05/15/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
My side by side Dometic is not cooling on AC. I am letting it run for a while before checking againt and attempting to try it on gas.
The flue is very warm to the touch and I have about a 3 amp draw on the fridge so I know that the electric heater is working to some point.
The coils on the back of the fridge are ambient temperature.
I am going through my troubleshooting book and doing some research on the internet. Any help would be appreciated.
Dave
Everett, WA
2000 Itasca Suncruiser 35U, F53 Triton V-10
Firestone air bags with Quad control air gauge
Pressure Pro
Banks Exhaust
rvsatek
AZ, USA
Posted: 05/15/08 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
If your flue is "very warm to the touch" and the coils are ambient temp: You probably have a blocked cooling unit and it will need to be replaced. On a side by side it is so expensive to replace the cooling unit you might as well buy a new frige. Any yellow powdery residue anywhere? Especially at the burner?
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
kamper00
Meriden, CT
Posted: 05/15/08 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Check your s/n, your fridge may be part of the recall, we had one that died and it was, they replaced the entire fridge.
Fulltimers
Anywhere, USA
Posted: 05/15/08 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
$2000 to fix
$4500 to replace not including removing the windwhield to get them in and out.
I would take the $2000 repair.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
Chris Bryant
DeLand, Florida, USA
Posted: 05/16/08 06:25am Link  |  Quote  |  Print  |  Notify Moderator
The first thing I would do is shut it off for a couple of hours, then turn it back on.
New models can get "vapor locked", and letting the pressure equalize will usually fix it if this is the problem.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
