RV.Net Open Roads Forum: Tow Vehicles: Frame Problem??????????????
Search only in Tow Vehicles
 > Frame Problem??????????????
The Mad Norsky
Yankton, South Dakota
Posted: 05/16/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Contacting Dodge about this worries me in that there are only 29,000 miles on this truck, and I do have warranty left.
I wonder what direction they would go with this??? In my mind, they would cancel any warranty I had left. Then again, maybe (what do I mean maybe, I know I ) worry too much.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
You dont necessarily have to give them your name and truck's VIN number to ask a question about the trucks. Pretend to be a prospective buyer asking about the trucks in general. I would advise though that the dealer probly doesn't know the answer to your question and may tell you something completely off-base. I would contact Dodge engineering dept directly. They are the likely the only people qualified to answer the question.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
bucky
Eastern Shore of MD
Posted: 05/17/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Any contact with Dodge would best be handled thru a local dealer that you already have a relationship with. And I would speak with the Body Shop manager only. He or she is the one that will know or have the proper access to any repair solutions on the frame involved. An alternative would be a body shop in the area that is respected and busy with lots of insurance co contracts. Maybe approach it as "could I get an estimate for removing this hitch and installing my new one?" Dodge and Ford are both quick to void warranty's or parts of them, depending on the local rep. I would hesitate to contact Dodge directly, because of your existing warranty. Or, tongue in cheek, look at TT's
99 F250 PSD CC LB 3.73 4X4 7360 lbs, and it can sink in the mud FAST, 2004 Coachmen Catalina TT 297RKS 8200 lbs on the road.
sirwilliam
BC
Posted: 05/17/08 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Trade the truck off for another one............
Steve
5'ER
TV = 02 CHEVY SILVERADO K2500HD DMXALLY XCAB LB, RANCHO SHOCKS RIDE-RITES INCAB CONTROLLER KIT BD-POWER XMONITOR CW PYRO BOOST DIGITAL INDICATION HI-JACKER DOUBLE PIVOT PRODOGY
5'ER = 03 CITATION SUPREME26RKS LDD WGT/PIN WGT = 10450/1800
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/17/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Contact Dodge engineering directly and don't give them your VIN number, just the year and model of the truck. I doubt the dealer knows enough about the metalurgical properties of the truck frame to give any accurate information about the effects of welding on it. Anything they say would be merely guessing, no better than we can do here.
Jumbo Cranium
Texas where else
Posted: 05/17/08 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Engineer9860 wrote:
I have read somewhere, because of the alloy steel in the Dodge truck's frame, that any welding at all was not recommended by Dodge.
I hope the welds don't lead to trouble later on. Even cutting off the old brackets, and grinding the weld smooth, still leaves the parent frame material's grain structure permanently altered.
Might want to conferr with your local Dodge dealer before continuing.
Not true at all. Dodges own TSB on the frame says welding is perfectly ok as long as "proper welding techniques are used, I did mine and its just fine.
Roger
Shelley, my sweet baby.
2006 3/4 ton Dodge QC CUMMINS 6 speed manual
2005 24' Trail Cruiser 5er
Jumbo Cranium
Texas where else
Posted: 05/17/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Here is the Dodge TSB. AFAIK the frames have not changed since '03.
TSB
The Mad Norsky
Posted: 05/17/08 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Jumbo, that surely settles my worries on the welding part of the problem. Thanks!
Now, hopefully Monday (the 19th) with visits to local dealers to Colibert and B&W both (may as well try a fitting, even though telephone said no way), the other problem will get solved.
camping man
Central Fla.
Posted: 05/17/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I'd grind it off too, and start over.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Posted: 05/17/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Find a welder that knows how to use a plasma arc torch and have them cut the old stuff out of your way. Then grind what's left if you need to smooth things out.
The plasma arc will input the least heat of any method available. You can write your name in sheet metal with one of these and the sheet metal won't warp at all.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress
Picture of '93 Mountain Aire Story of it's death by fire and explosion
