usksal08
Michigan
I have purchased a 30' trailer and have a weight distribution system from my last trailer with friction sway control. My last trailer was a Surveyor ultra light 27' I am a little worried about sway with my new trailer since I will be pulling it with short wheelbase 5.4 Expedition. Can I install a dual cam sway control with my existing setup. My trunnion bars are not the spring type and are rectangular on the end by the chains (quality S brand)
Any suggestions on how I can control sway without having to invest in a whole new weight distribution hitch? Since I normall only travel a couple hours away from home would the friction type be OK?
Terryallan
NC
usksal08 wrote: I have purchased a 30' trailer and have a weight distribution system from my last trailer with friction sway control. My last trailer was a Surveyor ultra light 27' I am a little worried about sway with my new trailer since I will be pulling it with short wheelbase 5.4 Expedition. Can I install a dual cam sway control with my existing setup. My trunnion bars are not the spring type and are rectangular on the end by the chains (quality S brand)
It can probably be added to what you have. Or. Add another sway bar to the other side of the TT tongue.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
H4Adventures
Minot, North Dakota
You should be able to find the opposite side easy enough on line...They are not ambidextrous from what I gather but please correct me if I am wrong.
2007 Zinger ZT30BH
2008 GMC Sierra 2500HD CC, 6.0/4.10
2004 Chevy Trailblazer
2003 Tracker Avalanche, 150EFI Merc.
rhondavid
Birmingham, Al
You do not specify the brand of your existing WD system,; however with the original versions of the Dual Cam you can purchase adapters if your bars do not have the cradle (crook) on them for the cam to rest on. These are usually pretty easily adapted to most bars. May take some grinding etc to make them fit but should not be too bad.
For the length of your TT I would not suggest friction control. It would not be able to handle the 27 feet that well and would be flushing your money.
I love my dual cam!!
David,Wife,4 kids,SIL,1 foster child,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
BarneyS
S.E. Lower Michigan
Yes, you can add the Reese Dual Cam kit #26001 to your present hitch and bars. See this post that I made recently about it and links to the kit.
The kit looks like this. Notice it has the bolt on ramps for the ends of the bars.
Barney
2004 Sunnybrook 30FKS TT
Hensley 1400# hitch
2002 Ford F250, 7.3L PSD, SuperCab, Short bed, Auto, 3:73rear
1996 Harley Davidson FLHRI Road King
Check out the new RV.net Blogs!
Visit our website here
luck would have it
Dimondale (Lansing), MI
Absolutely go with the dual cam. I just set this up on my Rig 3 weeks ago. Be prepared to do a lot of customization (depending on your spring bars). If it turns out that you do have to customize this setup, your best friend will be a dremal tool, an angle grinder, and BARNEY S!! Any questions you have will be answered by him. Just search for dual cam.
Also, Make sure that the tongue weight of your new trailer does not max out your previous spring bars.
Dave.
2004 Chevy Silverado Z71, Ext. Cab 5.3L
Prodigy Brake Controller
Husky WD Hitch
Dual Cam Sway Control
2007 27' Salem BHBS (Bunk Slide/Super Slide)
lat471
Lebanon, PA
I had the set up pictured by BarneyS and towed a 27' with a Yukon when I went to a 30ft I had to change to heavier bars so I went with a Equalizer 1200#. But that setup will work fine. Retire the friction sway. I have one in the shed and can't give it away.
07 Cameo LXI F35FD3
R Taj-We-Haul
usksal08
Michigan
Thanks everyone for the input. I definitely think I am going to go with the dual cam. If I already have the setup for the friction bar as well would there be any benefit to using both the dual cam and the friction bar or would that be more than I need?
Once I get the dual cam setup is there a lot of adjustment that is needed from time to time?
BarneyS
S.E. Lower Michigan
There is no need for the friction control once you have installed the Dual Cam. In fact, it could even be counterproductive because it may interfere with the operation of the Dual Cam's "return to center" feature.
One the Dual Cam is installed and adjusted correctly, there is normally no need to adjust it again unless you have need to re-adjust the whole hitch because of a different trailer, new truck etc. It may take a few trial and errors to get it adjusted right at the beginning though. It is very important that the Dual Cam be adjusted so the cams ride exactly in the center of the crook of the bars. If they do not, the sway control is greatly lessened and the Dual Cam fights with itself trying to keep the trailer in line.
Barney
NHguy
NH
Once set up you will love the DC. A hint, read the hitch setup sticky. It will tell you (between the lines) to make the initial WD setup with 2 extra links worh of chain before the DC is installed. When the DC goes on it takes up that amount.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, XM Cradle, Battery Disconnect
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
