RV.Net Open Roads Forum: Weber Baby Q and 20# Propane Tanks
 > Weber Baby Q and 20# Propane Tanks
jay2003
San Joaquin Valley, California
Posted: 05/16/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Do they work or don't they?
I was hoping to get rid of the green bottles since they're not so "green" in today's day and age. I wanted to get one of these extension hoses however after reading the reviews posted at Camping World it made me think twice. Seems like the few negagive reviews were from people with the Weber Q grills. They stated they didn't get enough flow from the hoses so little or no flame. The other grills seem to be ok. I love my Baby Q so I won't be changing it for the convienence of tossing the green bottles.
What do others use or what have others experienced?
Propane Hose
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
exfuzz02
Lakewood, WA
Posted: 05/16/08 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have used mine for several years with the larger propane tank. Works fine for me......Grills great steaks !!!
2007 Jayco 33DS, Greyhawk/Kodiak Chassis,Chev V-8
Toad: 2004 Jeep Liberty 4x4.
Dixonmatco
Santa Rosa, California
Posted: 05/16/08 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Yes that will work perfectly.. I use a 20lb tank (borrow from my home BBQ) but also use LP distribution tree with my lantern on top as in the picture. but it does use This hose instead.
The Baby Q has a regulator and is designed to run on full pressure LP, direct from tank.
BTW I love my Baby Q..
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
fulltimer5er
Central Vally
Posted: 05/16/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Had mine hooked to the 5 gallon tank for three years never a problem we bought the rolling cart and the tank sits nicely on the bottom shelf
2005 Dodge one ton duely quad cab navagation system don't want to get lost before were ready to
2005 Carriage carri lite 36 KIQ four slides {HOME}
Bessie-Hunter
Lyons, OH, USA
Posted: 05/16/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
The only draw back with those hoses is that if you open the service valve on the cylinder too fast, the excess flow thinks there is a leak and shuts off the flow of gas to the grill. Most people get in to much of a hurry and try to lite the grill after opening the valve and the grill will not lite due to the excess flow is in lockout. I tell my customers to make sure the grills valves are in the off position, turn the cylinder valve on, and walk away for 5 to 10 minutes. Let the gas system equalize to make sure the excess flow is opened to allow full flow of gas to the grill. But other than that they (the hoses) work fine, at least mine does.
Dave
Dave & Ellen, Don and Ross
'04 Dodge Durango 5.7 "Ya, it's got a Hemi" 3:55
Reese Dual-Cam WD
Jordan Ultima 2020
'05 Surveyor SV255RS
mike4947
N. Syracuse, NY
Posted: 05/16/08 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Just about all the bad reviews for the Q100 and larger grills deal with using a hose connected to the propane system on the RV not directly to a cylinder. The propane system after the regulator is low pressure and the larger Webers use high pressure (apx 13 psi) so they don't get enough pressure/flow.
The Baby Q actually runs on low pressure and has in internal regulator so you can run this grill on just about any propane source. Low pressure, high pressure, or directly from a 20 or 30 pound cylinder using a hose.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
swebber
Brunswick , MD
Posted: 05/16/08 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
We use a 20# tank (have one dedicated to the Weber) and a hose for our Weber. We even have a tee so that we can feed the Weber and the turkey fryer/ or my buddies grill.
I agree 100% on the close the grill valve and then open the tank valve slowly. You won't get much flow if you open it too fast.
Enjoy !!
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
jay2003
Posted: 05/16/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like maybe they reviewed the wrong hose? The one in my link has the Acme connector so you have to connected it directly to the cylinder. Connection to the RV would be a different hose.
JUrban
Delaware
Sounds like they were having problems with the excess flow preventers. Dave had it right as far as how to get the gas on. Both the Stay A While, some splitters and some LP hoses have flow restrictors in them. We use the Stay A While and I took the excess flow restrictor out.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
jay2003
Posted: 05/16/08 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Dave
Now there's an answer than explains a lot. Makes sense to me.. 12' hose and it shuts off after opening the valve too fast. The low flame reviews are probabaly from burning the residual fuel in the hose that got out when it was opened.
Definitely thanks for all the quick positive answers. I think I'm going to order one and give it a try. Down to my last green cylinder.
