RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: VACUUM PACKAGING
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > VACUUM PACKAGING
ehouk
Roamin', WY
Posted: 05/16/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone used the new Ziplock vac. packing device? I had large food save brand which worked well until I couldn't replace/fix the rubber gaskets. Since these are rather expensive I was wondering how well the Ziplock ones worked.
-Ed
2002 Chevy HD3500 Vortec 8100 LS Extended Cab Allison Series 1000 4.10 Rear
GVWR 11,400, GCWR 22,000
2001 Holiday Rambler Presidential 30SCD GVWR 12,500 Actual 11,500
CVW 19000+ -->    weight on loaded/hitched truck 10,400
My web pages
More photos
Super_Dave
Sacramento, CA
Posted: 05/16/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
There has been a couple of well documented threads on the topic if you can navigate the search function.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
SWMO
Southwest Missouri
Posted: 05/16/08 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
They work real well, but I have trouble reusing the bags and that makes them expensive.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
curt12914
Northern NY State
Posted: 05/17/08 07:02am Link  |  Quote  |  Print  |  Notify Moderator
My wife bought one for the camper. It works great! We especially like it for things (like cheese) that we want to use part of and reseal. It's much easier to open the zip-lock bags and to reseal them than it is to reseal with the older style sealer.
While the bags are more expensive (they aren't exactly cheap for the other sealer), the sealer itself is $7 compared to $100 for the older style.
I expect we will get one of the zip-lock sealers for the house, too.
05 Ford F-350 Lariat CC 4X4 PSD DRW Line X Retrax
02 Montana Big Sky 3295 RK (2) Honda EU2000is
When my grown kids were inspecting our new fifth wheel, one asked why we bought a trailer that sleeps 4. My reply was that we couldn't find one that sleeps 2!
SWMO
Southwest Missouri
Posted: 05/17/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Mine is still a work in progress. The bags have a mesh section that collects run off, and if its blood or something similar, its impossible to clean. I've done some by wrapping in clear wrap and freezing , and then vacuum packing it. If you defrost out of the bag it keeps them clean and as long as they're not punctured by a bone, reusable.
Sportsman2505qss
Winter Springs, Fl USA
Posted: 05/17/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
I use their Reynolds one that you can buy at Walmart for about $7.00. I bought the gallon size bags. I have found that if you use the cheap bags from glad called the Glad Twist and Tie, you get 100 of them, work the best for meat and fish. Just put your food in the glad bags and fold over. Then put in the Reynolds bags and vacuum down. When you take out of freezer, take the food out of the Reynolds bag and defrost. I have a cutting board with a handle and I put the Reynolds bag over the handle to dry out. I have reused them many times without a problem.
2002 KZ Sportsmen 2505qss bought in 2001 1999F-150
Gamble Rogers
AK Old Timer
Juneau, AK
Posted: 05/17/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
This month's Consumer Reports tested the Reynolds Handi-Vac Sealer and called them " the real deal".
 > VACUUM PACKAGING
