RV.Net Open Roads Forum: Towing: Trailer Lights
Search only in Towing
Open Roads Forum  >  Towing
 > Trailer Lights
OleMissTailgater
Corinth, MS
Posted: 05/16/08 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Guys,
I have a 2003 Chevy 2500HD with 7 pin trailer light/brake plug. I also have a splitter so I can pull my utility trailer with a 4 flat and I can not get it to work with the 4 flat. If you have a break controller does this screw up something with the 4 flat?
Tumbleweeds
Southeast AL
Posted: 05/16/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Ole Miss
All seven connections (actually usually only six, center is for backup lights and is rarely hooked up) have a separate wire from the front and shouldn't cause that problem. If it is a plug in adapter it could be faulty or if the splitter is wired in it could have been done wrong. Check the output with a test light or meter to be sure it isnt the trailer. Oh yeah check the white (ground) wire for connection to ground on both ends, lots of times it's that.
My Chevy came with a factory adapter that plugs into the 7 prong.
Good Luck
Tom
mooreadventures
North Carolina
Posted: 05/16/08 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
I use the adaptor plug all the time without any issues.
Have you tried testing the plug with a volmeter or test light? I wonder if something is wrong with it. If you're getting power on the 4 pin side, then there must be something wrong with the trailer wiring.
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
Excursion Meet in Gatlinburg, TN, July 25-27, 2008.
For more info ->Ford Truck Enthusiast - Excursion Forum
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
If no lights are working at all, I bet it's the ground connection, assuming the adaptor is fully plugged into the receptacle and the trailer connector is fully plugged into the adaptor.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
OleMissTailgater
Corinth, MS
Posted: 05/17/08 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have noticed that I do have running lights but do not have turn signals or break lights. So with that being said I believe the plug is working just not properly.
jtslj
Salt Lake City UT
Posted: 05/19/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
test your adapter. it may be bad.
I have had to replace many adapters over the years.
I have even had to replace the plug on my trailer due to lights not working properly.
1996 Chevrolet Suburban 2500 4x4 Vortec 5700
1987 Terry Tarus 29 R
 > Trailer Lights
