RV.Net Open Roads Forum: Tech Issues: Powdery stuff from batteries
 > Powdery stuff from batteries
retiredhappy
Kerrville, Texas
Posted: 05/16/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have two extra coach batteries in the compartment next to the door. Whenever I pull out the drawer there is a white/yellowey power under the batteries. What is this and do I need to be concerned? I use an old toothbrush to keep the posts clean and I check the water level pretty regularly. I also have an off/on switch so I can shut off the batteries. When I am plugged in should this be off or on? None of my manuals say anything about this.
Karen West
30' Gulfstream Ultra Class C
2001 Saturn
Two Spoiled Black Labs
ScottnSherrie
Augusta, GA
Posted: 05/16/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I believe that is sulfur powder from the sulfuric acid in the batteries. This could be a sign the coach batteries are getting over charged, causing then to boil and release the sulfur.
Hopefully someone who knows more about the subject will jump in and either confirm or refute my SWAG.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel
complete roof rebuild
daughter 15, son 11
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
USAFBILL
Alabama
Posted: 05/16/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly right, you need to get some baking soda and clean it up before it causes another problem.
lzasitko
Regina, SK Canada
Posted: 05/16/08 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Corrosion and most commonly around the posts. Take water and baking soda and wash the post. Probably get a battery terminal cleaner and clean both the post and the cable terminator. If you want to stop or reduce it a lot put dielectric grease on it, it will act as a barrier to water.
landyacht318
Near a large body of water
Posted: 05/16/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
I ran into this problem when I had two mismatched batteries in parallel. The stronger battery was getting overcharged.
I had so much powder built up I hosed it out, and then had to scrub my dad's driveway.
Now my batteries are matched, age make and model and I have no further corrosion issues.
smkettner
Posted: 05/16/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Check your charging voltage levels and water levels in the battery to minimize gassing that can push some sulfuric acid out of the caps. Once the battery is charged 13.2 to 13.6 volts is plenty. Check water after charging and it should be above the plates but below the split ring that extends down into the cell.
The white stuff is, lead sulphate, iron sulphate etc from the acid getting on the metals. It is water soluble but may take some time. Baking soda will neutralize the acid. Get to an autostore and buy some spray on battery terminal cleaner and a can of spray on protectant. Use this products generously to minimize future trouble.
tom_kat
way upstate new york/lake george area
Posted: 05/16/08 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
after cleaning get some battery terminal spray or the felt washers that go over the post they both work well for best results use both.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
1fastdad
mo.
Posted: 05/17/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
I don't know how old your battery's are but old battery's do this just before they need to be replaced. They don't hold a charge as long so the have to charge more and give of more gas.
Caseydon
Simonton, Texas
Posted: 05/17/08 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Be sure you aren't overfilling the batteries with water. That will cause normal gassing to spit electrolyte out through the vent caps. As you've been told, fill to just below the bottom of the split ring tube extending down from the top.
Casey
