RV.Net Open Roads Forum: Fifth-Wheels: fifth wheel set up
 > fifth wheel set up
Buslady
MO
Posted: 05/16/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hi to all. I know I have read some tips on this forum about older people and the front legs. We have problems with pulling the pin, and raising and lowering the front legs. We cannot bend and get up like we did when we were younger. I have used all the search terms I could think of, and did not come up with anything. Could someone point me in the right direction? Thank you all again. Buslady
Rug
GREED COUNTY, Boerne Texas
Posted: 05/16/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Do you want to replace the present landing gear with automatic hydraulic landing gear?
Do a search for Bigfoot hydraulic levelers.
What other help are you looking for if you do not want to replace your present landing gear?
Glen & Dee Ann
Truck
5th wheel
azjeffh
Chandler, AZ
Posted: 05/16/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I bet there would be many RV'ers willing to help if asked.
Jeff
Wonderful wife Robin, no children, no pets, no money
05 F250 Supercab SB PSD w/Tow Command
05 HR Savoy 29RKS
Martyn
Bennett, Colorado, USA
Posted: 05/16/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Have a look at these Support Leg Assistant A bit clumsy, but an option in development. Expensive too!
Here's their You Tube video
2004.5 Dodge Ram 2500 QC CTD 4x4 SLT; 2007 Coachmen Chaparral 267RLS;
Reese 15K Slider;Prodigy;JT Stabilizers;2 Honda EU2000i's;
2006 Glastron MX175;
rv-forums
2005 Dodge Magnum for the DW
donawilcox
Taylor TX
Posted: 05/16/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same problem at time and I am not even 40, luckily my 10 year old does them for me. I have had some back issues. Anyway, I wander if any one makes a spring loaded pin that would come in from both sides. That is where I have the issue is having to line the pin up. If that mechanism was more automatic one could find other ways to rais and lower the legs with some type of bar with out having to bend down. will be interested to hear if anyone has seen a easier pin system
Don Wilcox
Taylor TX
2006 Duramax 4X4
2007 295 Cherokey by Forest River
Desperado359
Moscow, Id.
Posted: 05/16/08 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
You would be looking for Snaps Spring-Loaded-Pins, they work great.
1995 Ram CTD 2500 SLT, 5 Speed, 4X4, 3.54, ATS manifold. B-D 4" Exhaust Brake, 4" Exhaust, Mach 3 EDM's, 191 DV's, Street “O” plate, 215 pump, 3K GSK, Isspro EV. Boost, EGT, gauge set, 502Hp Dt 8/2007 Webshots page
2001 24' 5Th wheel Cougar single slider
Vulcaneer
Northern New England
Posted: 05/17/08 06:14am Link  |  Quote  |  Print  |  Notify Moderator
Easy Lift Handles at bottom of page.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
GeeksRUs
Sundre Alberta
Posted: 05/17/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Do you use them??? How well do the work???
EH!
GeeksRUs
2008 Big Horn 3400RL
2003 F350, PowerStroke, 4x4, SuperCab, LongBox, SWB
RV Home Base @ Coyote Creek, Sundre Alberta
thecaptain
Belleville,Mi.48111 USA
Posted: 05/17/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
We use the spring loaded pins and I added a 3/4 dia. ext. long I bolt bolted to each landing pad and bent to miss frame . These work like a handle and make it better to use .
Ken/Ellen(RET)
2000 F250 Superduty
7.3psd/Banksbrake/Smartlock/Trans command/3.73gear/Edge EZ module
2002/29ft-Terry 5er:
Take life one day at a time.
Vulcaneer
Posted: 05/17/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
EH!
No, But thinking about it, tho'. For me the bending down is easy. It's the gettin' up that kills me.
