Charsweb33
Boise, Idaho 83712
I have the one piece plastic cover over the tub area and it has several small hairline cracks. Most were there right after the fver was new. Has anyone found a good method of sealing these. Even a good opaque coating is fine as we keep ours covered from the inside most of the time. The vent has developed more cracks with age. I don't want to just replace the vent, even if I could find a replacement.Thanks.
1992. Silverado 2500HD Ext. cab long box 454CI with owner installed Banks Power Pack 4L80E AT. 1997 Sunnybrook 5th Wheel, 27-foot with slide.I used to have a 1971 C20 Chevy and 1972 11.5 Saturn PU Camper.
dbates
Marion, Indiana
I had the same problem with my 98 Itasca & I used some epoxy glue that was designed for plastic materials. It appears to be holding but I'm afraid that with age it will start cracking other places & I'll have to replace it.
Click HERE for a company that might have a replacement for us both.
Dave
Plus New Brunswick, Prince Edward Island & Nova Scotia
Vet Man
Ct. & Florida
I got mine from the factory for free and it was not under warranty. Most have an inner and outer cover. I changed the outer in an hr very easy to do. The cracks will keep cooming.
2006 33ft Prowler TT
2006 44ft Breckenridge
2000 31ft Minne winnie
2008 Honda CRV Toad
2007 ZR1 Colorado Toad
2008 Pontiac Solistice GXP "Brazen Orange"
"We Traveled To Alot Of Different Places While On Vacation, Until The wife Asked Directions"
sonora
West Bend Wi.
Trying to go cheap and not buying a new replacement might cost you wood rot and structural damage. Be careful.
skyflyer
iowa
you could try a soldering gun with a plastic attachment.
you can use it to heat the sides of the crack and fuse them together.
Bob and Tammy
1998 31 fls golden falcon
2006 chevy silverado duramax
