big_murph_279
Concord, NC
Hello everyone, I am new to RVing. I have a 2007 27RB Salem camper. I have towed it several times since I got it in Feb. It does great on two lane roads. When ever I get on the inerstate it seems to move around a lot. It is fine unless I get near anything big, then I seem to be sucked towards it. I have towed many large trailers, but they were all open. This is the first closed in type of trailer that I have towed. I have a Reese dual cam WD hitch. I'm towing with a 2007 Chevy 1500 crew cab z71. If this is normal I'm ok with it, but if there is something I can do to help it I would love to try it. Thanks for any help.
CS_Grill Crew
Discovery Bay, Ca
Looks like you have sway control installed. Some tweaking needed perhaps?
See sway control
Also, how is the load in the trailer, centered over the wheel?
Here is some info:
http://www.propridehitch.com/trailer_sway/causes_of_trailer_sway.html
32 Winnebago Adventurer: Shreks Ride...
Luv to fish? Check out www.coastsidefishingclub.com
big_murph_279
Concord, NC
Well should the trailer get pulled toward large trucks? The weight in the trailer is centered over the wheels.
KC8WX
OH IO
We have the Wildwood 27RB. Last year on Interstate to Michigan, kept getting sucked into passing lane when trucks or other RV's came by. Was really a windy day, gusting 35-40 from the West side. Learned to watch the Driver mirror more and when I saw them coming, would hug the right side whiteline. That helped some.
This year I got more weight transferred to the front axle, sits much better now, axle drop equal within 1/4" front to back. Tows better. Using the Equal-i-zer.
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
CampSight
My trailer is tongue-light, so I had the same issues. On our last trip, I filled our 40g FW tank (ahead of the axles) before heading out and it towed like a dream.
mcoonan
Mendota Heights, MN
Read the info here:
Trailer Loading and Towing Guide
and here:
RV Towing Tips
Should help you solve your issues. Also do a search in this forum for Reese Dual Cam setup. (and the various abbreviations) There are some folks that have a lot of experience with the DC and the setup. (if your dealer set up the DC make sure you redo all the setup).
Good Luck!
Mike
'05 Cherokee 28DD
'04 Expedition w/HD tow package.
Hensley Arrow and Jordan Ultima 2020
Scrib
San Jose, CA
I agree with CampSight - sounds like you need more weight on the hitch. This will help your dual-cam, too.
Good luck!
The Family Camping Blog
Camping tips for the family, camping gear that makes backcountry camping more enjoyable and general camping-related news that might be of interest to the family camper.
BAJA X
Minnesota
What I do when a semi is going to pass me on the freeway is slow down about 5 mph and when the semi is just at the rear of my trailer I slowly speed up and have found this to work against the sucking in effect.
08 F-350 4X4 Crew Cab Lariat Super Duty V-10 Tow Command 4.10
Tow Beast Receiver 1700# Reese W/D Dual Cam sway
08 XT30SB CrossRoads CrossForce
04 650 Baja X
04 400 XT Outlander
89 Springer Softail
5weekendwarriors
iowa
Sounds perfectly normal from what I can remember pulling with a half ton. I just learned to watch the mirrors, and be ready for it. I don't notice it as bad with my new tv.
- 2008 Dodge Ram 3500 Megacab Dually 6.7 CTD 68RFE 6 Speed Auto 3.73's
- 2009 Keystone Sprinter 311BHS
- Equalizer 12000# Hitch
- 2007 Jeep Commander
- 2004 Lowe Suncruiser 20' Pontoon
- Gone But Not Forgotten
- 2006 McKenzie Starwood 30CKS:2001 Jayco Eagle 304BH
TURK2500
S.E., Michigan
Jeff,
As stated earlier, the "bow wave" effect that you are experiencing is normal. IMO the best way to minimize this effect is when you realize that you are going to be passed by a large vehicle (semi, motorhome, etc.), stay to the right allowing as much space between you and the passing vehicle. Also maintain your towing speed and be mindful to not "oversteer" in an attempt to counter the effect. I tend to keep my TV/TT in a straight line without having to make any steering corrections while experiencing a minor "bow wave" from a passing vehicle.
If you have the Reese HP Dual Cam hitch, the lower section of this Towing forum STICKY will walk you through the adjustment process to insure that your Dual Cam system is adjusted correctly for optimum TV/TT handling characteristics.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
