RV.Net Open Roads Forum: Dinghy Towing: GMC Envoy
Search only in Dinghy Towing
 > GMC Envoy
DaveHallmark
California
Posted: 05/16/08 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'd like to know if anyone has experience towing a GMC Envoy 4WD. I'm looking at a 2004 in great condition and real low mileage. The dealer started reading the manual where it tells you how to disengage the drive train. I didn't really get it all, but it sounded a little involved. Is it really, or do you get used to it quickly? I'm used to pulling a Jeep Wrangler, where I just pull the lever into neutral and go.
2007 Safari Cheetah pulling a 1998 Jeep Sahara
Dave and Cheryll
Rollincool
Always Rollin
Posted: 05/16/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Steering doesn't lock on those so your good. Just turn the transfer case knob to engage neutral, if it's manual shift, put in park, release parking brake and tow away. Pretty much the same as your jeep.
If it's electric shift you push the 2 wheel high and the 4 wheel low together for around 10 seconds, and the drivetrain is dropped in neutral automatically.
Have fun.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6349
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - K•Hits 106.7
DaveHallmark
California
Posted: 05/16/08 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks a bunch, it dosen't sound too complicated. It's an automatic if that makes a difference. I'm going back for another look in the morning, so maybe I'll try it while I'm there.
chuck4788
West of the Middle
Posted: 05/17/08 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I've towed two Chevy Trailblazers, which are sister to your candidate Envoy and they tow well. The setup sounds complicated but after a few times is easy. My 02 required pulling two fuses which was a PITA, my 08 doesn't, so like Rollincool said it is pretty straight forward. Over the years these rigs used several different control switches for the transfer case; some had a neutral label, some didn't, some with a knob, some with buttons. My 02 and 08 have a knob without a marked neutral position, but it is there.
03 thru 05 models are pretty much the same, in 06 there were changes to the engine, and again in 07 and 08. Somewhere along the way side air bags were added. In 06 or 07 they increased the spring rates which really improved the handling from a wallow wagon to a pretty decent drive. My 08 is nite and day better than my 02. Adding Bilstein HD shocks will be money well spent.
I set up both for towing using Roadmaster brackets, a Sterling tow bar and Brakemaster brake system. PM me if you want more info on my setup.
This Trailblazer/Envoy forum has some good info.
Good luck
* This post was last edited 05/20/08 12:50pm by chuck4788 *   View edit history
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
havasufun
Big Bear Lake, Ca (Snow Summit)
Posted: 05/17/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have a GMC Envoy 4X4 SLT all options (power / leather/air suspension) already set up to tow with the Roadmaster XL brackets.. its a 2002 with 55k miles very easy to tow (no fuse to pull) push a button put it in park lock the doors and go. It has the roadmaster round 4 wire plug for lights.
I don't use it anymore (I have an H3 and Ram 1500 I pull).. one of my kids is using it.
I would let it go for $11,000
What price are you paying?
If interested
pbedoe@juno.com or PM me on this site
Paul
* This post was edited 05/17/08 03:19pm by havasufun *
2004 Alfa See Ya Gold 40' 400 ISL, Hummer H3 Toad,Ram 1500 4X4 Quad Cab Toad, 24' Hallmark Cargo Trailer, 20' Carson Toy Hauler when we need the extra room.
 > GMC Envoy
