RV.Net Open Roads Forum: Travel Trailers: slide out question
 > slide out question
virstens
Sioux Falls, South Dakota
Posted: 05/16/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have two small jacks that are to be used to hold the slide out in. Has anyone ever used them or had a slide out come out while on the road? Do not know if I need to use them or not.
1 wife that loves to camp
2008 Cirrus 27CRB
2008 Silverado Max Ext Cab 6.0
Pictures
SuperDutyMan
Western PA.
Posted: 05/16/08 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Some TTs have them,some don't,they are used usually on the hydraulic ones more than the screw type.
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
subourbon
Huntsville, AL
Posted: 05/17/08 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Do you use the Jacks to keep the slideout from extending while towing? Thats why you have them, in order to keep the slideout from extending while on the road. Be on the safe side and use them.
Happy Camping
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Prodigy Brake Control
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
Hornet28BHDS
Parker, PA
Posted: 05/17/08 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
If they came with your TT, you need to use them.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
pacificnw
Great Northwest
Posted: 05/18/08 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Yep, I have one... it goes in at the top of the slide and holds it snug to the body of the TT.
5weekendwarriors
iowa
Posted: 05/18/08 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Had them with my starwood tt. (electric slide) Never used them, it never came out on me going down the road. Didn't come with my new sprinter. (hydrolic slides)
  • 2008 Dodge Ram 3500 Megacab Dually 6.7 CTD 68RFE 6 Speed Auto 3.73's
  • 2009 Keystone Sprinter 311BHS
  • Equalizer 12000# Hitch
  • 2007 Jeep Commander
  • 2004 Lowe Suncruiser 20' Pontoon
  • Gone But Not Forgotten
  • 2006 McKenzie Starwood 30CKS:2001 Jayco Eagle 304BH
chevyman2
missouri
Posted: 05/19/08 12:30am Link  |  Quote  |  Print  |  Notify Moderator
The old TT (NASH) had 2 of them. I used them just because I had them. My new TT (Coachmen) didnt come with them. I say "If you have them use them, if not dont worry about them"
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 95 Firebird(da toy)
07 COACHMEN SOA 32FKS(stress relief center)
If Im not at the CG---I'll be somewhere else!
Total nights camped in 08 = 45
statehoss
Pittsburgh
Posted: 05/19/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
My trailer came with them as well. I have two slides on the Rockwood. Problem is that the locks are designed to be placed against a rather lightweight perimeter trim on the slides and also compresses the interior seal so that it is "pitted" . Big warning sticker, "do not overtighten as damage will occur to trim." Seems like more of a gamble to use the things than not. My slide are electric on a rack. They have never moved even slightly.
Trimble1
South East Michigan
Posted: 05/19/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure you remove the jacks before trying to open the slide out. Or you will be on the roof putting the trim seal back on...first hand experience.
jim
stugpanzer
Illinois
Posted: 05/19/08 08:51am Link  |  Quote  |  Print  |  Notify Moderator
So....do you use them or not? Just curious as I have a new Rockwood and have used them...
2008 Rockwood Signature Series 8314SS
2001 Ford Excursion w/V10 6.8L
Reese WD Hitch w/HPDC
Don't forget to visit the RV.Net Blogs!
