RV.Net Open Roads Forum: How to rewire front TV for use during driving????
 > How to rewire front TV for use during driving????
hansonug
Colorado
Posted: 05/16/08 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have a '95 Damon Intruder (Class A) and was wondering if anyone has rewired the electrical to the front TV to allow it to be used while the engine is running. I am decent at electrical stuff but just don't know where to look or how this outlet is being shut down when engine is running. Don't worry, I don't plan on watching the TV while driving, it is for my young family. I am sure I am not the only one that has wanted to do this.
Thanks...
Fire Instructor
Upstate (Albany) NY Area
Posted: 05/16/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
This was discussed a couple of months ago, but I couldn't find the thread... anyway, there is a relay that senses tat the ignition is on, and kills the power to the outlet. As I recall, some were able to find the relay and disable it, others just run a lead-cord to an out let that stays hot while traveling.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
"If everyone is thinking alike, then somebody isn't thinking!" General George S. Patton
tatest
Oklahoma
It's been done. There is a relay activated by the ignition switch, to shut off that outlet. It should be near the outlet or near the ignition switch.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
ThunderingQuiet
In Your Mind
Posted: 05/16/08 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Check the outlet where the TV is plugged into. On our mh the relay/socket was plugged into an outlet and the TV was plugged into the relay/outlet. I just removed the relay/output and plugged the TV into the outlet.
No more ignition controlling the TV...
garym114
Posted: 05/16/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
It is being shutdown by the 12v wires that go to the outlet. When the ignition is hot a 12v relay in the outlet box disconnects the 110v in the outlet.
Mine was a duplex box. Took all of that out and put new outlets in, wired straight to 110v.
Cause I wanted to.
2000 Sea Breeze with 1998 CRV Toad in Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
dcbrewer
kentucky
Posted: 05/16/08 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
On our's there is an outlet beside the one that TV was plugged into, as easy as unplugging and plugging back in 4" over. Now that makes a lot of since, but than maybe Fleetwood got it right.
sum1
So-Cal
Posted: 05/17/08 12:33am Link  |  Quote  |  Print  |  Notify Moderator
In some coaches, the fuse is labeled "TV Interlock"
GaryDuarte
Florence, S.C.
Posted: 05/17/08 05:18am Link  |  Quote  |  Print  |  Notify Moderator
In my 06 Damon Daybreak, the live plug is right next to the Interlocking plug in the cabinet to the right of the TV.
Papa's driving the new Daybreak
Jaden and Minnie are CoPiolets
Mickey is navigating
happycampinman
Michigan
Posted: 05/17/08 06:50am Link  |  Quote  |  Print  |  Notify Moderator
In my MH in the power panel in the engine bay is a fuse labeled TV interlock, Remove fuse and TV works. Dont worry most people with kids want the TV to work, great entertainment option while traveling.
2008 Hurricane 34 B
2007 Pontiac G6
fourfurz
Memphis
Posted: 05/17/08 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Is this some sort of rule for gas MH's only? Our MADP's tv always works regardless of ignition on or off. Glad for that, can't watch the "Weather Channel" without the TV!
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
