RV.Net Open Roads Forum: eye to eye turnbuckle opening up on eyes
 > eye to eye turnbuckle opening up on eyes
jendiro
Lancaster, CA
Posted: 05/16/08 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 25 inch extension on my tow beast in order for me to pull my CRV with my Lance 1010/ Silverado 2500HD Truck Camper.
I run a chain from the back of the truck chassis( on either side ) towards the end of the extension. At the end of the chain I use a 3/8" x 6" eye to eye turnbuckle to keep the chain nice and snug and to prevent the extension from moving a little left to right and VV.
After driving some 20 miles the chains on both sides are hanging loose and the eyes of the turnbuckles are not eyes anymore but hooks.
I picked up these 3/8" turnbuckles at Harbor freight and they look and feel pretty solid. I do not know what their break point is listed as though.
When these eyes open up I can feel a little bit more fishtail at the back of the camper and that I think is due to the shaft of my toad's towbar moving a little left to right in the hitch opening. Turnbuckles come in a lot of different strentghs I guess and although these feel very solid they might be too weak. This is just my opinion. I am not very mechanical.
Any ideas on this to prevent the little bit of fishtail?
* This post was edited 05/16/08 10:22pm by jendiro *
2002 Silverado 2500HD
Lance camper 1010
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Use higher-quality turnbuckles made of grade 5, or better yet, grade 8, US steel. Chinese steel is real junk. Sometimes there are truely great deals there on some pretty descent stuff, but often times at Harbor Freight, you get what you pay for.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 05/16/08 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
Use solid eye turnbuckles instead.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
JeepDaddy
Kent, WA
Posted: 05/16/08 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do not use turnbuckles for this application, use chain binders. I have a 42" extension towing a CJ7 and I have never had a problem.
2002 2500HD, 4x4, E-cab, 6.0L, Lance LC 780 11'3"
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/17/08 01:20am Link  |  Quote  |  Print  |  Notify Moderator
Chain binders, good idea
FreeLanceing
Grand Haven Mi
Posted: 05/17/08 05:19am Link  |  Quote  |  Print  |  Notify Moderator
You can weld those shut in pinch. As was stated earlier those are more of the same Chinese junk. There steel has a fraction of the strength of US made rigging. When your safety and our economy is at stake buy American.
dieselgrin
Virginia
Posted: 05/17/08 05:35am Link  |  Quote  |  Print  |  Notify Moderator
If you go for chain binder, look at the ratchet type vs. the flip over type. The rachet's are much easier to adjust the tension. I user to carry a small cheater pipe to get more leverage when hauling equipment. As I got older the pipe would have to get longer.
2002 Silverado LT, 2500HD, Duramax, Big Allison, 4x4 Crew
Bridgestone Dueler A/T Revo 245/75/16,...
Fleetwood Angler
VintageRacer
Dundas, Ontario
Posted: 05/17/08 06:21am Link  |  Quote  |  Print  |  Notify Moderator
I would toss the chains and just use the extension the way Reese designed it. I use the same extension to tow a 7500 lb trailer and it's as solid as a rock back there.
brian
2003 Dodge Ram 2500 Quad Cab, Hemi, 5 speed manual, 3.73 gears, Tow Beast hitch with 24" extension.
28 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
2004 Travel Hawk 8' Truck Camper - Roll at 16K combined weight
Myasis Dragon
Ottawa, Ohio
Posted: 05/17/08 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I often thought that if I had to use a hitch extension, I'd use a pair of Torklift tie-downs (Fast Guns) to stablize it. Haven't checked into it yet, but I bet they'd work pretty well.
Jon Loman
Jon & Anita Loman
2006 Chevy Silverado 2500HD
Ext. cab, 8 ft. bed, 6.0 liter, 4sp auto
Timbrens, Torklift tie-downs w/Fast Guns
1991 Fleetwood Caribou
2-2002 Sea Doo GTX RFI's
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/17/08 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Camper tie downs would probly work too, they are basicly turnbuckles with some rubber cushion to them.
I agree ratchet binders tighten just right, whereas flip binders are sometimes either too loose or too tight.
Welding on that junk Chinese steel probly just result in a crack next to the weld and the whole eye end breaking off eventually.
Definately, buy American wherever possible!
