TandA-n-Mac
new jersey
newbee to forum, are there any jayco legacy owers out there?
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
Hoops
Indiana
We have one. In fact we are on our second one. We have the 38RDQS and it is great. We have yet to find any thing new that we prefer more.
The Hoops. ED and Becky
Missy our little Bichon
2004 F350 V10
2005 Jayco Legacy 38RDQS
5thwheeltowboy
Western Pa
Have a 2002 313 Eagle now and just ordered a 2009 Designer 35RLTS. The Eagle has been a good performer and hope to have the same success with the designer.
Ninebell
Bardstown,Ky
we've got the 2007 34RLQS Designer
Ninebell,the Wife,and Ginger the Shiz-zhu
2008 F-450 Lariat PSD,DRW,CC,LB,4X4
2007 Jayco Designer 34RLQS.
My Photo's
JEBar
Willow Springs, NC
I've heard that Jayco is going to come back out with their Designer Legacy series .... they are supposed to build it in the factory they bought when Travel Supreme went out of business .... if they do, it will be interesting to see what they come up with
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
TandA-n-Mac
new jersey
thank you everyone for your reply; does anyone have a crack at bottom left corner at bedroom slide? had mine repaired before pick up but it came back; durning my research for 5er i have read about this continuing problem,but just cosmedic.hoops do you feel it necessary to add second ac in bed room? or have you been comfortable?
CHV_FRK
Black Jack, MO
What would be the difference in the Designer Legacy and the Designer. I just figured they phased out that part of the name.
Dana and Natalie
2008 Chevy Silverado 3500HD LT DRW CC LB 4x4
2008 Jayco 35RLSA 38'9"
Piney Boy
TN
My neighbor has one. It's about a $10k option
USA in a Chevrolet
Manahawkin, New Jersey
CHV_FRK wrote: What would be the difference in the Designer Legacy and the Designer. I just figured they phased out that part of the name.
In 2005 when I bought my Designer, the Legacy model had wooden blinds, 2nd tv in bedroom, 2nd ac, better fiberglass exterior, round table instead of rectangular, & a few other things. About $6,000 more.
USA in a Chevrolet
TandA-n-Mac wrote: thank you everyone for your reply; does anyone have a crack at bottom left corner at bedroom slide? had mine repaired before pick up but it came back; durning my research for 5er i have read about this continuing problem,but just cosmedic.hoops do you feel it necessary to add second ac in bed room? or have you been comfortable?
I had the crack below the corner of the bedroom slide. When you say you had it repaired, do you mean the fiberglass or the problem causing the crack? The crack comes because the frame around the slide opening is weak. The only repair involves removing the fiberglass & welding new gussets on the aluminum frame. The procedure is very specific & takes about 40 man hours. The slide must be removed while this work is done. Jayco should cover the frame repair under warranty. What model do you have? I had my Dealer, Whitehorse RV in Williamstown, NJ take care of the repair. They are excellent. This should cost you nothing & it must be done correctly or the crack will come back. If you have any other questions, PM me.
