RV.Net Open Roads Forum: Toy Haulers: Flat sceen TV Mounts
Search only in Toy Haulers
 > Flat sceen TV Mounts
Teebone56
Dublin California
Posted: 05/17/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Anyone have any Creative ways of mounting a Flat screen in the existing hole. I was hoping to go larger and would like the mount to swing out. hey picture would be great!
2009 Weekend Warrior SL 3005 Superlite Billet Edition
2007 Silverado 2500HD CC SB 4X4 6.6 D/A
04 DS 650 Baja X
07 Rhino SE
ronfisherman
SE Michigan
Posted: 05/17/08 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a thread that I posted in last month. Overhead TV. I have cleaned up the holes by putting some oak paneling over the holes since pictures were posted.
The more I use digital TV programs, the more I like it.
Saf-TTE tire monitor
Al/Reeni
Ft Myers, Fl
Posted: 05/17/08 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Twelve dollars in parts from Lowes.
cruz3
Tri-Cities, WA
Posted: 05/17/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
I used a standard mount, but it is 'facing' toward the wall and mounted on the front of the cabinet. The bolt heads on the right of the picture are the mounting bolts. The TV mount allows the tv to fold right back into the hole. I made the DVD mount from those plates used to hold trusses together and painted them.
2007 Thor Vortex 22FB
2002 Chevy K2500HD CrewCab LT 8.1L/Allison
Equal-I-zer/Prodigy/Equa-Flex
7 MPG towing, but it goes faaaast
LowRyter
OKC
Posted: 05/18/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a swivel mount on the right side of the opening. I put the screen under the bed when we travel. I can pull it off and set up in other places, even outside if I have long cable.
Teebone56
Dublin California
Posted: 05/18/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Guys
cruz3
Tri-Cities, WA
Posted: 05/19/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
If I had it to do over again, I'd look toward one that is a quick adjust model. Mine is adjustable with an allen wrench and it is a pain to remove the TV. It was only $35, so I can't complain too much.
bandmjdavis
Virginia
Posted: 05/19/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Google Premier Mounts if you really want something fancy. They may even customize something for you if you want them to.
'05 Keystone Spningdale with Bunkhouse
'07 Dodge Ram 2500 CTD SRW 4X4
3 Happy Campers
JSGrewal
Simi Valley, CA
Posted: 05/19/08 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
I did almost exactly what cruz3 did right down to the same lcd, except mounted the lcd a little higher in the opening for DVD access and I use the other space for chargers ( cell phone, ipod, two way radios, etc).
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6
