ResearchMan67
Seminole, Fl, USA
just replaced (3) deep cycle batteries. charger is boiling the new batteries; admitedly I did top off with some distilled water and prob. a wee bit too much, but... they were new off the shelf. I went in and stepped down the charge to 5 and hope that's the ticket. I really think it's why I only got 18 mos. out of these batteries the first time. Engine batteries seem to be fine.
this is an '07 Winne Tour. Any similar experiences.
ResearchMan67
2007 Winnebago Tour 40TD, 400hp Cummins, Freightliner/Allison,
Saturn VUE (6cyl/auto/FWD-2004), BlueOx,Adventa II
Hurricaner
Hurricane Utah
I bet you have the famous Dimensions inverter/charger...corect! There is a problem with some of these as they won't go into float mode. Check the voltage on the display it should say 13.2 volts float, if not contact Dimensions.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
You can't take the Fisherman out of this Camper
Ontario, Canada
Do you have, or have you recently installed a Shurflo Ceiling Exhaust Vent Fan? If so, I can explain why you have this problem... and how to solve it.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: FINALLY... 2002 Cougar 276EFS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
brobox
Sunny SW. Florida
When I purchased my TS the inverter/charge was set to high and had cooked the batteries when I bought the coach 18 months old. I don't know if the previous owner messed with the settings or if it came from the factory that way. There is a chart in my owners manual for setting the charger for the total amp hours of your batteries. Mine was set on almost double, way to high. After replacing the batteries and setting the charge to the proper charging rate, the batteries are now 4 years old and still going strong.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
hohenwald48
Hohenwald, TN
I've purchased 3 used motorhomes in the last 5 years and every single one of them had the wrong battery type selected on the Xantrex inverter/charger. The OP doesn't give us any info as to the type of inv/chg he has but if it is Xantrex and the charge setting he talks about lowering to 5 is in fact the "Power Share" setting then it does nothing to vary the charge profile. I guess we need a little more detail to be of any real help.
Chris
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
Wherever I happen to park
I agree with the need for INFORMATION
Make and model of inverter/converter please
Hurricaner
Hurricane Utah
Quote: Do you have, or have you recently installed a Shurflo Ceiling Exhaust Vent Fan? If so, I can explain why you have this problem... and how to solve it. OK, lets here it.
Sam
Bea PA
Waynesboro, PA, USA
The Demensions in Winnies are a known problem, we lost 5 batteries before we fhad it fixed. As the former post said, call Demensions.
Bea PA
2004 Winnebago Journey
2008 Saturn Vue
1998 Venture Van
Brake Buddy/Remco Pump
2003 Gold Wing 1800 (Big Red)
Ontario, Canada
Hurricaner wrote: Quote: Do you have, or have you recently installed a Shurflo Ceiling Exhaust Vent Fan? If so, I can explain why you have this problem... and how to solve it.  OK, lets here it.
Sam
Do a search on my posts using the words "Electrical Puzzle"
Hurricaner
Hurricane Utah
OK, I read it and it does not apply to this situation. You were dealing with a Magnetek 6300 linear converter(just a guess), this is a inverter/charger, totally different animal.
Sam
