RV.Net Open Roads Forum: Class A Motorhomes: inverter/charger boiling batteries
 > inverter/charger boiling batteries
ResearchMan67
Seminole, Fl, USA
Posted: 05/18/08 11:29am Link  |  Quote  |  Print  |  Notify Moderator
OK, it is a Dimensions 2000 watt. After I stepped down the charger to 5 amps it stopped boiling over and later I checked and it did go into float mode.
I'm still not comfortable with it; and will try to determine what setting it's on. Manual states "there is a battery selector switch located on the right side of the chassis that must be set to the type and size of the battery bank...." (gives examples). That's interesting since all my batteries, ATS, etc. are on the left side of the chassis.
ResearchMan67
2007 Winnebago Tour 40TD, 400hp Cummins, Freightliner/Allison,
Saturn VUE (6cyl/auto/FWD-2004), BlueOx,Adventa II
