RV.Net Open Roads Forum: Fifth-Wheels: Slide-Out Awnings...Yes or No
 > Slide-Out Awnings...Yes or No
msredneck84
East Central Mississippi
Posted: 05/17/08 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
My first fiver didn't have them and I installed topper's for many obvious reasons. The coach I now own doesn't require toppers because the mfg. engineered the slideouts so as not to require them. Interesting don't you think?
HUTCH45
NORCAL
Posted: 05/17/08 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
YES.....! You'll never forgive yourself if you don't....
...Enjoy the journey folks...
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
LipDawg
Canfield, Ohio
Posted: 05/18/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
We have a Cruiser with the toppers and have never had water come in as we retract the slides. Personally, we would not be without toppers. YMMV
LipDawg
2006 Crossroads Cruiser CF29RE
2005 GMC 2500HD 6.0L, 4.10
The adventures of Chip N Nia
NC Hauler
Asheville NC
Posted: 05/18/08 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Never have had water come in when retracted and topper was wet or had a pool of water on it. I highly recommend them. They help keep the top of the slide out clean. I've also had no real problems in high wind. I want to know about the posters 5er above that has been engineered to where the slideouts don't need toppers...how does that work?? Fascinating. Your money will be well spent if you purchase the slide toppers.
Jim & Kathy
07.5 Chevrolet K3500DRW/CC/LB/LMM/D/A LTZ, Prodigy,Reese 20K hitch.
06 HR Presidential Suite 37RLQ
06 Coachmen Clipper Classic 1270ST
99 Jayco Quest 10
07 Mitsubishi Outlander XLS 4X4
Boxers,Sheba,13..Buddy..1.5 yr.
USAF 71-75 Nam Vet
Dayle1
Spicewood, Tx
Posted: 05/18/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Not only will pooled rain not get into the interior, sleet and snow can build up on the s/o awning and it will fall off as the s/o is closed. Without the awning, you risk damage to the seals or s/o, climbing on the slick roof to remove the ice buildup, or waiting for warmer weather.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'03 GMC 2500HD D/A EC SB, Jordan controller, custom RKI bed/hitch, Putco boards, TF 45gal tank, grey Speedliner
'04 CrossRoads Cruiser CF29RK, Mor/ryde IS, Carefree Eclipse 12V awning
Rig Photos
mr. ed
Madison, SD (currently traveling the US)
Posted: 05/18/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have slide-out awnings but I wouldn't mind having one on the bedroom slide-out because it would diminish the sound of rain hitting the metal roof of the slide. The noise keeps me awake...it's NOT soothing, although others think it is.
That being said, I don't mind getting up on my step ladder and brushing off the slides before retracting them. I'm tall and can reach them easily. A fellow RVer I met in WA last year had slide awnings on all his slides and told me he didn't really like them. According to him, leaves and other junk still found their way onto the slides and he had to maneuver a broom between the awnings and slide with some difficulty in order to brush them clean. I guess it's a case of: some love 'em and some don't. To each his own...
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
mwebber78
New England
Posted: 05/18/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I skimmed the posts so excuse me if I repeat some theme's -
Negative:
I didn't get these on my prior trailer with a slide
Positive:
-No water, debris or other junk on the slideout roof
-Reduces some of the heat by blocking the direct sun from beating down on the slide roof.
-Protects the seals from water intrusion
-The Carefree of Colorado model's come with a wind baffle cover to reduce the "buffeting" in high wind, it also looks more finished then the Dometic A&E models (IMHO).
-I camp at a seasonal with a ton of pine trees. The awning keeps ALL pine spills off the actual roof and away from the seals. This means NO pine pitch to remove from the slide roofs.
I am very happy with ours, I have two of them. There is enough pitch that only the heaviest rain causes some pooling. You can simply draw in your slide, it will drain the water and put the material taut again.
PS- I really like that Cruiser and we are hoping maybe sometime next year to get the trailer you are looking at.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Champion lil' yellow Chinese genset, 4000W
Camping Pictures
Norm K.
Destin, FL or on the road!
Posted: 05/18/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, by all means. We've never been sorry we installed them.
Norm (also a retired airline Capt.)
'03 Silverado 2500HD Dmax/Allison XCab LB 4wd
'04 Montana 3400RL
Champ198
Lebanon, Tennessee
Posted: 05/18/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
PMiller228 wrote:
My DW and I are wanting to order a Cruiser CF32BL from RVWholesalers. We don't know if we should get the slideout awnings or not. There would be three of them for the three slideouts on the CF32BL.
Here are the negatives we've heard:
-They get dirty from mold/mildew
-They "flap" in the wind
-They can pool water on them and when the slideout is brought in, the water can come into the interior
Postives are:
-They protect the slideout by keeping debris off the top of the slideout
-They keep the RV cooler
If the awnings are worth it, and will help protect our investment, then we definitely will order them. If they're not, then it's money we can save.
Thanks!!!
You hit the nail on the head with those pros and cons. (except for the part about water running in as you bring the slide in.) I have them. I believe they keep trash off the slide roof and water away from the seals, reducing the chance for leaks. But, your observations are dead on. This is a 100% personal preference and I can see both sides.
Duane & Amanda, a teenager, A golden retriever named Jazz, a crazy pet rabbit named Stew, and now Optimus Prime the hamster.
2008 Cedar Creek Silverback 30LSA
2008 Ford F250 Lariat SC 4x4 PSD 6.4, Timbren SES, Husky 16k Slider
GreenSalsa
Monterey, California
Posted: 05/18/08 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
We have and love them...never had a problem with the water
2006 Ford F350 CC PSD DRW
2007 Cedar Creek 362BTS
GreenSalsa is a married Army Special Forces family that is "fulltimeing" while stationed at Naval Postgraduate School, Monterey, CA
Registered on ProfessionalSoldiers.com and Socnetcentral.com
