RV.Net Open Roads Forum: Replacing 14" x 14" vent with powered Turbomaxx or Maxxair
 > Replacing 14" x 14" vent with powered Turbomaxx or Maxxair
BiggSean
Posted: 05/17/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
So who has replaced a standard 14" x 14" vent (without fan) and replaced it with an aftermarket vent fan such as a turbomaxx, or maxxair? I'm thinking about swapping out the plain old vents in the bunkhouse, and master bedroom of my KZ2809 with one of the aforementioned fans, and was curious as to the difficulty of the install, since there isn't any wiring in their locations.
2007 Escalade
2006 Dodge Ram Mega-Cab, Cummins turbo-diesel
2005 Subaru WRX
2008 Coachmen Chaparral 299TSB fifth wheel trailer
bkempton
Dracut, MA
Posted: 05/17/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have been think of doing the same with the one in the bathroom. This one is wired for that cheap little fan that is in there but i might swap it out with one of the ones you have mentioned. Just out of curiosity, what are you towing your 2809 with? the Escalade? How does it tow?
BK(37), SK(34) & AK(41 months)
2006 Chevy 2500HD Ext Cab 4x4 LT2
2000 Chrysler Concorde LX
2005 KZ Frontier 2809PQS-F
1998 Ski-Doo Formula III 700R
1998 Featherlite Enclosed Snowmobile trailer.
BiggSean
Posted: 05/17/08 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Fow now I'm towing it with the Harley F-150, as it has the more stout motor between the two, being that it's modded (500hp/600tq). If the occasion arises where we are taking more than 4 people, then we'll consider using the Escalade. I have no doubt that the Escalade would handle the load with ease.
V10 man
Mesa, AZ
Posted: 05/17/08 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Pull out the insides of the vent and see if there are wires available. Is there a light near by? You could tap into that but watch the amp ratings.
2007 Dodge 6.7 Cummins, 6sp auto, Quad cab, long bed, white, Prodigy
2009 Shockwave T29FBSP, white & blue, tan interior, 4000W Onan, Reese Dual Cam 15K/1,500.
BiggSean
Posted: 05/17/08 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
No wiring in there, so I guess I'll just tap into the adjacent light circuit. I like the concept of the turbomaxx fan since it mounts onto the existing vent, and prevents the end user from having to worry about going through the sealing process.
How does the turbomaxx fan compare to the Shurflo gold or platinum series in terms of performance?
BiggSean
Posted: 05/18/08 11:05am Link  |  Quote  |  Print  |  Notify Moderator
After doing a little more research, I'm 90% certain that I'm going to go with the Shurflo gold series fans throughout the entire TT. They seem to perform very well, and I like the fact that they can be operated with the lids closed as a ceiling fan. That feature should make our 90-100 degree days MUCH more bearable when used in conjunction with our air conditioner.
I have a question regarding installation. Should I use lap paste, along with putty tape over the seams of the vents when installing them? Or is lap paste enough to get the job done right?
bluwtr49
Green Valley, AZ
Posted: 05/18/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Last year we replaces two of our vents with Shurlfo units about 1/3 of the way through our trip...same prinicpal, and the differance is night and day. The one in the kitchen sucks, and the one in the bedroom blows so we have great circulation. They open and shut based on the thermostat setting. After a long hot day on the road, the TT used to be so heat soaked that he AC had a heck of a time bringing the temp down. Now we let the vents do there thing while on the road and even in hot weather it's much cooler inside when we arrive.
Overall, a wise investment
Dick
2008 Toyota Tundra Crew Max Limited TRD
2009 Cougar 268 RLS ~8400 lbs road wt
Equal-i-zer 12,000 lb hitch, Prodigy BC.
2006 Jeep Liberty Turbo Diesel.....TV in Training
2005 Jeep GC 5.7 HEMI,(retired)
2005 Jayco Jay Feather 25Z, 4" lift (Retired)
BiggSean
Posted: 05/18/08 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Holy cow, it was 105 degrees out here today, and the AC was having a tough time cooling my TT down. I'm definitely ordering these fans tonight. I'm just trying to decide whether to replace only the vents in the front and rear of the TT, or all three. Do you guys think it would be worthwhile to replace the cheapo fan in the bathroom area with a shurflo while I'm at it? There is an AC vent directly next to the bathroom vent, so I was thinking it could help with moving cold air from the midsection of the TT.
scout3399
raleigh nc
Posted: 05/18/08 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
i like the tubomax the fan is up and away so alot less noise
you can run is 24/7 in the rain get the one that has the temp control you can set it if tt get hot along the road or in storage is come on and air out
BiggSean
Posted: 05/20/08 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I pulled the trigger and purchased two gold series Shurflo fans, and just finished installing them tonight.
The selling point for me on these fans were their ability to be used with the lids closed, and the AC turned on. That said, these fans move a tremendous amount of air, and I think I'm going to be real happy with them out in the field.
